Auto trunk doesn't close all the way...HELP
2007/S8
Pressing the button in trunk to close it does actually close it
the problem is that it doesn't close all the way where it trips the sensor closed. it looks closed, just not enough to trigger that sensor. if i push real hard on the trunk i can then hear it 'click' shut and i hear some motor engage something.
i have no codes so just seeing where a good place to start diagnosing is and if anybody had any ideas on what the issue is
Thanks!
Thanks!
Do You Have All the Tools in Your Toolbox?
2007/S8
Thanks!
Thanks!
i'm not sure if i have that plastic motor, not sure where to locate it?
Easy way to test the locking mechanism. open the trunkl use a rod or a screw driver to lock the mechanism. see if you can force it open witth screw driver. It shouldnt take too much force to see ift the mechanism is worn. if its worn, just buy an new one and replace.
is that would it could be? i thought maybe the trunk wasn't closing hard enough. when i manually close the trunk or i push it down after that motorized closing, i can hear the lock latching. so could it just be the force needed to latch it isn't enough?
AudiWorld Wiseguy
The trunk latch failure is very common across many VAG vehicles. The same part was used pretty much across the board. It usually rears it’s head in cold weather, but can sometimes just happen.
Replacement is straight forward DIY and it solves the issue permanently.
angelglo - it was spring on the latching post. it was missing. bought a cheap spring, modified it and hooked it on. no more issues
GUEST123
S4 (B8 Platform) Discussion
05-30-2011 09:36 AM
