Backup camera
Old Jan 15, 2016 | 08:21 AM
cstarky15's Avatar
Default Backup camera
Hello All Wise and Powerful AW,
My backup camera on my 07 S8 seems to have stopped working. It was hit or miss when placed in reverse for about a week but now the past 3 days it doesn't work at all. The MMI screen just stays on whatever screen is up at the time. The rear sensors still work but not the camera.
I thought originally that the cold weather was the issue but we have had a couple of warmer days and still nothing.
Thoughts?
is there a specific module I can scan that would tell me with vagcom?
Old Jan 15, 2016 | 08:28 AM
Darren Coogan's Avatar
It's happened to me a few times in my S8. I found that pressing the parking button and/or shifting from park and back again made it work again
Old Jan 15, 2016 | 09:23 AM
Shamoye Lewis's Avatar
Engineer
do a full scan and post the results
Old Jan 15, 2016 | 09:24 AM
mishar's Avatar
Tech Guru
There is specific module, but it can be connection or camera or something else. VCDS scan should help.
Old Jan 16, 2016 | 07:39 PM
cstarky15's Avatar
Here is my scan: I cleared them and rescanned. All that came back was the navigation malfunction. I didn't drive the car around so tomorrow I'll see if the others come back.
Saturday,16,January,2016,20:59:02:37301
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Ross-Tech: Home
VIN: WAUPN44E57N011549 License Plate:
Mileage: 157880km-98102mi Repair Order: 858
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44E57N011549 Mileage: 157880km-98102miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 1010
77-Telephone -- Status: OK 0000
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348JX067508352
Coding: 0000003
Shop #: WSC 02313 785 00200
VCID: B36F5A57D2A45DA626-80E6
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000025669
Subsystem 3 - Serial number: 0117.11.060000000100010136ÿ
Subsystem 4 - Serial number: 010136ÿ
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 88
Reset counter: 215
Mileage: 156438 km
Time Indication: 0
Date: 2015.12.07
Time: 08:27:33
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A298160
Coding: F5D5DFFF707A0E
Shop #: WSC 02120 444 12486
VCID: ECDD812BCF1AC25E27-80B8
2 Faults Found:
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 156365 km
Time Indication: 0
Date: 2015.12.04
Time: 21:20:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 215
Mileage: 156365 km
Time Indication: 0
Date: 2015.12.05
Time: 08:05:30
Address 1E: Media Player 2
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: AA514733056E1C6E95-80FE
1 Fault Found:
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 203
Mileage: 157655 km
Time Indication: 0
Date: 2016.01.12
Time: 19:32:51
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381J.067509772
Shop #: WSC 02120 444 59879
VCID: B8756D7BCBC2BEFE13-80EC
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 255
Reset counter: 215
Mileage: 156366 km
Time Indication: 0
Date: 2015.12.05
Time: 08:14:52
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000022512
VCID: A045A51B7352D63ECB-80F4
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 321109907S
Coding: 344530393135313035412056413033323131303939303753
Shop #: WSC 42540 000 1048576
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 157611 km
Time Indication: 0
Date: 2016.01.11
Time: 16:32:39
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Time Indication: 0
Date: 2016.01.11
Time: 17:18:41
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 157626 km
Time Indication: 0
Date: 2016.01.11
Time: 17:19:27
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 157626 km
Time Indication: 0
Date: 2016.01.11
Time: 17:19:37
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 157626 km
Time Indication: 0
Date: 2016.01.11
Time: 17:19:47
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6910QS
Coding: 1121402
VCID: DCBDD1EB1FBAB2DED7-8088
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 215
Mileage: 156365 km
Time Indication: 0
Date: 2015.12.05
Time: 08:05:30
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730630406850
Coding: 0221208
VCID: A34FAA176244CD26D6-80F6
2 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 197
Mileage: 157549 km
Time Indication: 0
Date: 2016.01.08
Time: 20:44:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 198
Mileage: 157141 km
Time Indication: 0
Date: 2015.12.30
Time: 12:53:53
Old Jan 23, 2016 | 02:24 AM
Engineer
in the trunk on the left side behind the MMI modules Access panel theres a small black box...
Check the connectors, then locate the fuse and check it.....
Old Feb 17, 2016 | 09:28 PM
ebi718's Avatar
I was looking in right compartment of trunk for the RVC controller module but couldn't find it. Couldn't find it in the left either. Is it likely it was relocated for MY '09 A8?
Old Feb 17, 2016 | 10:13 PM
storka's Avatar
On top of your nav DVD player ?
Old Feb 20, 2016 | 04:52 PM
ebi718's Avatar
That's the Parking Assist Module, not the rear view camera control unit.
Old Feb 20, 2016 | 05:30 PM
storka's Avatar
Oops
Not sure I retro fitted mine.
Supposed to be next to radio on the left side or left side in trunk behind seat.
<table class="cc abstand-standard erlaeutrg-explo"><tbody><tr><td class="einzug-nummer">9 - </td><td>Reversing camera system control unit -J772- behind luggage compartment side trim (front left)
</td></tr></tbody></table>
File Type: pdf
File Type: pdf
