Battery coding-message- uninitialized control module warning
Old Jan 5, 2017 | 11:59 AM
johnd64's Avatar
Default Battery coding-message- uninitialized control module warning
I'm trying to code the battery I put in 1 yr ago.First time using the VCDS for this purpose.I have only used it for scans.
I wasn't sure if it was safe to do it since I got this message .
Thank you
Old Jan 5, 2017 | 12:04 PM
mishar's Avatar
Tech Guru
There is no need to code battery year after you installed it. Coding it right after replacement would say to the system that there is a new battery. Until now, actually much earlier, system found it out itself.
Old Jan 5, 2017 | 12:29 PM
johnd64's Avatar
I was hoping to get rid of some of the errors in the scan.
Quiescent current ....
Old Jan 13, 2017 | 01:35 PM
thetruewheeler's Avatar
Did you follow the Ross Tech install tip? Just about ready to do mine after nearsly 6 years.
Old Jan 13, 2017 | 04:54 PM
johnd64's Avatar
I did follow the instructions but I didn't know what to do when I saw that message.I was afraid to proceed so I still haven't done it.
I read what the message means but I still don't know if it's safe to proceed.
Old Jan 13, 2017 | 10:02 PM
mishar's Avatar
Tech Guru
Originally Posted by thetruewheeler
Did you follow the Ross Tech install tip? Just about ready to do mine after nearsly 6 years. https://www.youtube.com/watch?v=IJAScg6JrYI
That instruction is BS. You can use any battery (size meters), code it by changing a single digit, or not code it at all and nothing will happen. If you don't code it will take few hours for the module to figure out new battery.
Tbone6283
Apr 7, 2019 11:22 AM
Bob Petruska
Q5/SQ5 MKI (8R) Discussion
25
Jul 28, 2018 07:33 AM
raaizin
Oct 13, 2016 11:02 PM
TFT
20
Mar 9, 2015 05:44 AM
Chango
Mar 8, 2011 11:37 AM
