Battery Dead-key stuck
My battery is totally dead, and the key is now stuck in the ignition. Now that it is this dead I can no longer get to the trunk to charge the battery. I called the dealer and they said they can't advise what to do, but that if I fed voltage to the fusebox directly, I could pop the trunk. Does anyone have any experience with this and know the fuse location to feed the car enough to do it?
Thanks in advance.
Thanks in advance.
This was covered in a recent thread. There is a cover over the key release on the left side of the key, remove it first. Search for which direction to turn the key, can't remember off hand (thinking its to the left. Then insert a pic or paper clip turn the key the other direction. This might be in the owners manual as well.
Thanks in advance.
Thanks in advance.
Now you can open the trunk, charge the battery, etc.
Keyfob reprogramming problem......after searching i tried both the owner's manual way, and the other
boogs
11
07-23-2007 02:53 PM
JayS8
12-18-2003 08:50 AM
