Black screen problem
2004 A8L
Radio not working most of the time...then out of the blue it starts up again.
Screen sometimes pops up ...sometimes not.
When its all working it it works fine.
Have heard a popping noise now and then from the back of the cabin when it tries to boot up.
When screen comes on with logo screen...stays lit for a few seconds then back to black. Only changes made are : New dealer nav disk installed. Worked fine for months. Genuine Audi Loopback Fibre Optic Bridge Wire Loop 2-pin Connector 4E0973802 ordered.
VCDS scan results below:
Thursday,13,April,2017,07:11:17:55863
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
Data version: 20170320 DS267.7
Ross-Tech: Home
VIN: WAUML44E34N009917 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E34N009917 Mileage: 116040km-72103miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0C8523066
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F18EA285BB07F8F343-804A
1 Fault Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 008 - Implausible Signal
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0019751
Coding: 0000002
VCID: 2412E5C472D65C57691-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02120 000 00000
VCID: 211CECD06DC4497F027-8074
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C8523066
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58EA81347E1EC8B7359-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Shop #: WSC 00000 785 00200
VCID: 2310E6D877D85B6F10B-8076
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000020 Serial number: 00000000024663
Coding: 1085761
VCID: 5AEE9B3C0012DAA703D-800E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H01 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H01 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO18092003065A000000000140ÿ†89
Subsystem 5 - Serial number: 000140ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO18092003065A00000000
Subsystem 7 - Serial number: 65A000000000139ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A0E0BFC10F28A2753D-807E
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 114938 km
Time Indication: 0
Date: 2017.04.06
Time: 07:20:59
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H09 0920
Coding: 0530707
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
01742 - Igniter for Knee Airbag; Drivers Side (N295)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012241
VCID: 6594B8C0396C655FBEF-8030
Component: Lenkradmodul H03 0070
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0080
Revision: D11 Serial number: AUDID3C8003794
Coding: 0000223
Shop #: WSC 48618 001 1048576
VCID: 5CE29D240A262497111-8008
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 02005038030782
Coding: FCFE7BDD1B2304
Shop #: WSC 00000 000 00000
VCID: 2616FFCC04EAAE47775-8072
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 109
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:05:30
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2514F8C079ECA55F7EF-8070
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0060
Coding: 4071650
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000322900057
Coding: 0003989
VCID: 1D64D02051BC6D9F26F-8048
1 Fault Found:
02282 - Sunroof Drive; Obstruction Detection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 101
Mileage: 115080 km
Time Indication: 0
Date: 2017.04.08
Time: 16:47:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EE6972C1C3A36877F5-800A
1 Fault Found:
01340 - Mirror Adjustment Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 106
Mileage: 115904 km
Time Indication: 0
Date: 2017.04.12
Time: 08:57:18
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040309110208
Coding: 0065086
VCID: 2708F2C803E0B74F4C3-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:10:05
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000022286
Coding: 0010111
VCID: 5DE49020113C2D9F66F-8008
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T06RDE
1 Fault Found:
01064 - Terminal 58d; Interior Dimming
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 4
Fault Frequency: 12
Reset counter: 106
Mileage: 115156 km
Time Indication: 0
Date: 2017.04.10
Time: 10:30:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 02120 444 58842
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Freeze Frame:
Voltage: 9.73 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Coding: 0000001
VCID: 629EA3DC284212675BD-8036
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000003801107
Shop #: WSC 02120 444 58762
VCID: 1E66D72C5CBA76873F5-804A
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 330126Q20Y
Coding: 303030393135313035414B56413033333031323651323059
Shop #: WSC 44320 000 1048576
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5F98AA281B303F8F743-800A
3 Faults Found:
01472 - Aerial for Monitoring Front Left Tire Pressure (R59)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 106
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:04:10
Freeze Frame:
Speed: 0.0 km/h
Voltage: 11.20 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 54
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:04:09
Freeze Frame:
Speed: 0.0 km/h
Temperature: 0.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 114959 km
Time Indication: 0
Date: 2017.04.07
Time: 09:12:47
Freeze Frame:
Speed: 91.0 km/h
Temperature: 0.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3003916
Coding: 0000005
VCID: 609AA9D4265E00774D9-513C
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: 609AA9D4264E00774D9-8034
1 Fault Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 56
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.07
Time: 09:03:13
End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.5V)-----------
Thursday,13,April,2017,07:13:41:55863
VCDS Version: Release 17.1.3 (x64)
Control Module Part Number: 4E0 910 468 A
Component and/or Version: Gateway H07 0030
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
47-Sound System ERROR ERROR
56-Radio OK OK
37-Navigation OK ERROR
Ross-Tech: Home
Coding: 0007773
1 Fault Found:
Coding: 0000002
Coding: 0007597
Coding: 0263168
Component: ELV XXXX
Coding: 3940576
Cannot be reached
Coding: 1085761
Coding: 0111113
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 114938 km
Time Indication: 0
Date: 2017.04.06
Time: 07:20:59
Cannot be reached
Coding: 0530707
2 Faults Found:
Coding: 0012241
Coding: 0000223
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:05:30
Coding: 0263168
Component: ELV XXXX
Coding: 0015510
Coding: 4071650
Cannot be reached
Coding: 0003989
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 101
Mileage: 115080 km
Time Indication: 0
Date: 2017.04.08
Time: 16:47:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 106
Mileage: 115904 km
Time Indication: 0
Date: 2017.04.12
Time: 08:57:18
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:10:05
Cannot be reached
Coding: 0010111
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 106
Mileage: 115156 km
Time Indication: 0
Date: 2017.04.10
Time: 10:30:00
Coding: 0028196
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Freeze Frame:
Voltage: 9.73 V
Count: 61
Coding: 0000001
Address 56: Radio
Cannot be reached
Coding: 0028196
Coding: 0212127
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 106
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:04:10
Freeze Frame:
Speed: 0.0 km/h
Voltage: 11.20 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 54
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:04:09
Freeze Frame:
Speed: 0.0 km/h
Temperature: 0.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 114959 km
Time Indication: 0
Date: 2017.04.07
Time: 09:12:47
Freeze Frame:
Speed: 91.0 km/h
Temperature: 0.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028196
Coding: 0000005
Coding: 0001208
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 56
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.07
Time: 09:03:13
56-Radio OK OK
You need at many optical ring/loop bypasses as the number of devices you disconnect. Back in that area, yes sat radio if you don't have the module or entirely disconnected. But if you pull a bypass there without a device, ring would fail just from that. Haven't played with it, but if you can eliminate by tying both ends of Nav unit into active ring, now you would have the bypass freed up as a loop tester.
Yes, you can leave it in full time of course. I guess I don't understand what your question is. I thought you were going after the CD drive, which is up in the glove bx and connected by the optical loop. In turn I thought you were trying to bypass it for some reason and wanting to borrow the optical bypass where your sat radio tuner would otherwise be.
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:05:30
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:05:30
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 69
Mileage: 114945 km
Time Indication: 0
Date: 2017.04.06
Time: 08:05:30
