Center differential being replaced....finally
61,000 mi.
Brought my 2006 A8L to the dealer last Monday (been in there over a week). My car was making a weird vibration on 90 degree+ turns upon acceleration from a standstill. The dealership said they could not replicate the noise/vibration, so I went in and took the service advisor for a quick drive (me driving) in the parking lot. He definitely felt it and proceeded to bring out the mechanic/tech to listen.
I received a call yesterday about a discussion they had with AoA on the diagnosis and was told they were going to replace all of the differential fluid with some different type of fluid that they've had some success with. After adding the fluid the sound/vibration was still there (perhaps even worse). They have now decided to replace the entire central differential.
It seems that this problem is intermittent, which is why it took so long to diagnose. I thought this post might be helpful for anyone else experiencing the same problem.
Enjoy!
I am shocked the techs did not understand how the Audi system works.
Good Vibrations
there's a problem with strong vibrations on the A8 and A6 4.2 coming from the rear differential pinion shaft bearings and spacer/adjuster.
183-525-261
183-525-267
087-407-551-a
the spacer shrinks over time allowing excessive play in the bearings and causing that strong vibrations on tight turns.
The diffs never lock in any way shape or form and there is means of locking them. The front and rear are free, open completely normal diffs while the centre is torque dependant in as much as it relies upon the worm and gear principle which allows limited rotation in some situations. Pulling away from standstill on firm ground is not one of them.
The vibration is caused by backlash in the whole drivetrain excentuated by the accerman effect of turning a tight radius. The centre diff shifts from directing drive to the front and rear because at low speeds it is not good at seeking out lost traction. It 'sees' the speed difference as a potential loss of traction at front because in a tight turn the front diff will rotate faster, so it switches torque to the rear, then it tries directing torque back to the front and continues this shifting pattern until something else changes - either you come of the turn or speed up.
A new car will do it but it is more obvious in a higher milage car with more wear in the drive components. As far as I can see, it nothing to worry about and unless you replace every component in the whole drive train, it is not possible to eradicate it.
