Do I need to re code the battery after I disconnected it
Hi every one first I want to thank you all for all the information you guys are posting here it helped me a lot .
Not long ago I thought I bought a lemon , but with your help I managed to bring the car to almost perfect condition ( it's still a 10 year old car) I am enjoying the car like it should be enjoyed.
Now to my question , I disconnected the battery because I had to change the lock on the right back door it didn't open from the outside, and beside that there was a fault code on the door, and from what I read here it drains the battery so there was no escaping fixing this problem . the Instructions on the web is to disconnect the battery when you work on the door. The repair went well the door works and the fault code has gone.
But I still have battery problem, after two days with no start there isn't enough juice to start the car and I have to jump start the car and clear fault codes. that are connected to low battery. the battery is two years old . Is it a problem that the I need to re code the battery or need to replace battery .
No, you don't ever need to recode battery when you simply disconnect it. BUT, if you replaced it two years ago, was it recoded then? If not, obviously still probably not coded correctly.
FWIW, I personally think the system probably eventually figures out if a battery is replaced, coding or not. But it isn't documented. If it doesn't, system logically only uses decay algorithms and likely then time based, or maybe with a start count and/or run time layered on. Speculation though.
Even at two years old, you can sometimes have a bad battery, especially if it has been fully discharged a few times. Also possible you have a current drain somewhere. If your door handles are the keyless/comfort entry type, they are a known occasional battery discharge problem when defective. A VCDS scan will likely give you clues on other items causing a battery drain (car alarm horn and various audio/receiver components are other known examples), plus of course a change to check/confirm battery coding.
Thank you for your prompt replay, answers :
1 battery was replaced by previous owner at the dealer the sticker from the dealer is still on it with the date so this is how I know it is two years old, now if it was done at an authorized dealer I presume they coded it .
2 After I completed the work on the door I did a VCDS scan again and I have an historic fault code :
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040610280231
Coding: 0000588
Shop #: WSC 02313 785 00200
VCID: 2A0DFC5730F184B7161-807E
1 Fault Found:
00984 - Left Tail Light (M4)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 18
Mileage: 95570 km
Time Indication: 0
Date: 2014.11.30
Time: 11:57:37
this fault code is on all scans I did from the first time I started working with VCDS , the left tail light works fine all lights are operating as they should , at 2014 the car was with the previous owner so I don't know what was and where was the repair done and I don't know what is missing in tail light to fix this fault.
Beside this fault code the scan on the car is clean . The measuring values with vcds on the battery regulator are in check where they should be , I check also that the battery will charge to 100%.
That's how I left it today , will see how long it will last.........
Coding: 0000588
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 18
Mileage: 95570 km
Time Indication: 0
Date: 2014.11.30
Time: 11:57:37
update:
Next day (Tuesday) the car barely started but started, after a short drive and a short stop tried to start and no start . Jump started the car with a booster and drove the car home. The next day (Wednesday) the car started with no problem had a long drive with it , after a long stop ( about 6 hours)the car started with no problems, on the way home I stopped at the dealer to buy a new battery and left the motor running . They didn't have the battery in stock and had to be ordered . As I got in to the car and started driving the radio suddenly went silence, the lights on the screen was and the MMI where still on , I tried to switch to CD the CD play but no sound . By the time I got home the screen went black and staid up the light on the MMI went dark . As I got home I did a scan :
Wednesday,05,September,2018,17:48:36:60126
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
Ross-Tech: Home
VIN: WAUZZZ4E77N011269 License Plate: 20-000-62
Mileage: 132520km-82344mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 38 42 46 47
4F 52 53 55 56 61 62 72 76 77
VIN: WAUZZZ4E77N011269 Mileage: 132520km-82344miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth.
Cannot be reached
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 A HW: 4E0 920 901 A
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3FN003161
Coding: 0000113
Shop #: WSC 00008 730 12573
VCID: 1E6520877CB97817638-804A
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
008 - Implausible Signal
Freeze Frame:
Fault Status: 00000011
Fault Priority: 6
Fault Frequency: 25
Reset counter: 106
Mileage: 132192 km
Time Indication: 0
Date: 2018.08.22
Time: 00:20:27
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000306A138056
Coding: FCFE7BDC2B1104
VCID: 270B056323E3B9DF10E-8072
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Mileage: 132468 km
Time Indication: 0
Date: 2018.09.05
Time: 15:42:22
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 106
Mileage: 132477 km
Time Indication: 0
Date: 2018.09.05
Time: 16:10:30
Address 1E: Media Player 2
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 G
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F9109608
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E9769F5E1DC627694-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
4E0905852E ELV 1940
No fault code found.
Address 34: Level Control
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory FS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670114
VCID: 2411126F52D552C735C-8070
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Trsteuer.FS BRM005 0180
Coding: 0028448
VCID: 20191E7F46CD4EE7514-8074
Cannot be reached
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000096419
Coding: 0010101
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Trsteuer.BF BRM005 0180
Coding: 0028448
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000022726
Shop #: WSC 00063 730 21606
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2611030399
Coding: 344530393135313035412056413032363131303330333939
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Trsteuer.HL BRM005 0180
Coding: 0028448
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Trsteuer.HR BRM005 0180
Coding: 0028448
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730630407116
Coding: 0201008
VCID: 2313117357DB55FF4C6-8076
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:00, VBatt start/end: 11.7V/12.2V. VIgn 0.3V)------
Today I got the battery installed it and coded it . Started the car and it started with no problems and right away, took it for a short drive around the block , the MMI was still dark and the screen still up and dark , took another vcds read (after clearing the first one) and this it :
Friday,07,September,2018,15:54:35:60126
Ross-Tech: Home
Mileage: 132710km-82462mi Repair Order:
VIN: WAUZZZ4E77N011269 Mileage: 132710km-82462miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
34-Level Control -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
Address 01: Engine Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 HW: 4E1 907 560
Component: 4.2l V8/4V 0030
Revision: 71H16--- Serial number: AUX3Z0F9109608
Coding: 01060003190F0120
Shop #: WSC 00001 730 89315
VCID: 5F9B5D833B33311F28E-800A
1 Fault Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 132716 km
Time Indication: 0
Date: 2018.09.07
Time: 00:27:26
Freeze Frame:
RPM: 639 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 54.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI RdW 0010
Revision: --H01--- Serial number: 4254349
Coding: 0000001
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 221D147748C15CF7470-8076
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Coding: 0263168
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Component: Sitzmemory BFS H02 0010
Coding: 3670112
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 F
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000106882
Coding: 0037185
VCID: 1C612A8F6AA56A078DC-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0043122
VCID: 3635D827F449D0579B8-8062
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P0G03WWW
Coding: 0431707
Subsystem 1 - Serial number: 63328RB401A28419D
Subsystem 2 - Serial number: 63428RB401A283ECT
Subsystem 3 - Serial number: 63528RB401A283F7Q
Subsystem 4 - Serial number: 63628RB401A283A2H
Subsystem 5 - Serial number: 63729RB401B8508CS
Subsystem 6 - Serial number: 63829RB401B850DE-
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksהulenmodul H14 0040
Coding: 0012041
VCID: 65974F6B196F6BCFE22-8030
Component: Lenkradmodul H07 0090
Coding: 0000113
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 34
Reset counter: 148
Mileage: 132192 km
Time Indication: 0
Date: 2018.08.22
Time: 00:20:27
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 41
Reset counter: 108
Mileage: 132521 km
Time Indication: 0
Date: 2018.09.05
Time: 18:39:01
Cannot be reached
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 2809065F2EFDB6A7194-807C
Coding: 3670114
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000628500062
Coding: 0003092
VCID: 1D67278B71BF630F7A2-8048
Coding: 0028448
Coding: 0000588
VCID: 2A0DFC5730F184B70F0-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 108
Mileage: 95570 km
Time Indication: 0
Date: 2014.11.30
Time: 11:57:37
Cannot be reached
Coding: 0010101
Coding: 0028448
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000921
Shop #: WSC 00001 730 51399
VCID: 1F1B1D837BB3711F68E-804A
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D27C70BD17F030F5A2-8068
Address 56: Radio
Cannot be reached
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 070928S0GE
Coding: 303030393135313035444C56413030373039323853304745
Shop #: WSC 12345 128 00289
Coding: 0028448
Coding: 0028448
Coding: 0201008
Cannot be reached
End----------(Elapsed Time: 01:39, VBatt start/end: 12.5V/12.3V)-----------
Any suggestions or related threads to fixing this new problem
Ross-Tech: Home
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Address 15: Airbags
Cannot be reached
Cannot be reached
Coding: 0000113
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 25
Reset counter: 106
Mileage: 132192 km
Time Indication: 0
Date: 2018.08.22
Time: 00:20:27
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Mileage: 132468 km
Time Indication: 0
Date: 2018.09.05
Time: 15:42:22
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 106
Mileage: 132477 km
Time Indication: 0
Date: 2018.09.05
Time: 16:10:30
Cannot be reached
Coding: 0263168
Component: ELV 1940
4E0905852E ELV 1940
Cannot be reached
Coding: 3670114
Cannot be reached
Coding: 0028448
Cannot be reached
Cannot be reached
Coding: 0010101
Coding: 0028448
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Coding: 0028448
Coding: 0028448
Coding: 0201008
Cannot be reached
Ross-Tech: Home
1 Fault Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 132716 km
Time Indication: 0
Date: 2018.09.07
Time: 00:27:26
Freeze Frame:
RPM: 639 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 54.0°C
Voltage: 13.589 V
Coding: 0000001
Coding: 0008597
1 Fault Found:
000 - -
Coding: 0263168
Component: ELV XXXX
Coding: 3670112
Cannot be reached
Coding: 0037185
Coding: 0043122
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0431707
Coding: 0012041
Coding: 0000113
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 34
Reset counter: 148
Mileage: 132192 km
Time Indication: 0
Date: 2018.08.22
Time: 00:20:27
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 41
Reset counter: 108
Mileage: 132521 km
Time Indication: 0
Date: 2018.09.05
Time: 18:39:01
Cannot be reached
Coding: 0263168
Component: ELV XXXX
Coding: 0015510
Coding: 3670114
Coding: 0003092
Coding: 0028448
Coding: 0000588
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 108
Mileage: 95570 km
Time Indication: 0
Date: 2014.11.30
Time: 11:57:37
Cannot be reached
Coding: 0010101
Coding: 0028448
Revision: A32C0220
Coding: 0000921
Coding: 0000006
Address 56: Radio
Cannot be reached
Coding: 0028448
Coding: 0028448
Coding: 0201008
Cannot be reached
DesmoTesta
9
11-25-2002 03:09 AM
