Fault codes : P1577/P1573
I searched through and lot of confusing information but I am not clear.
one question other than fixing is can I live with this issue or it must be taken care.
i went through lot of repair this month from diagnosing and replacing my rear passenger strut to replacing break pads and rotors front and rear.
just taking a breather and found these codes , any help is appreciated.
Trouble codes:
P1577 - Right Electro-Hydraulic Engine Mount Solenoid Valve Open circuit No signal/communication
static
P1573 - Left Electro-Hydraulic Engine Mount Solenoid Valve Open circuit No signal/communication
static
Trouble codes:
static
static
Trouble codes:
static
static
Trouble codes:
static
static
If you forgo this and manage to find a youtube video that shows you this information, including the proper way to remove and replace the mounts along with torque specs and which fasteners to replace and which ones are Torque to limit which have specific procedures to follow so your powertrain does not fall out under load from snapped bolts etc. Print out this for your garage:
Audi Teilekatalog Parts Catalog Online
Modestly priced basic online manual w/ subscription access: http://alldatadiy.com
You should consider getting a repair manual. Or, find a research librarian...or maybe Google...to work for free?
I finally was able to get under the car and was able to spot the engine mounts .
They are psychically good.
I also tested by giving acceleration and checked engine, and it seems stable.
But when I went under it oily all over and the electrical wire and connections are oily, I am guessing this oil made the sensors to go bad.
I had to top off oil few times and it appears this is leak is the cause of the low oil level.
I was watching few youtube videos and they are talking about valve cover gasket and may be some o-rings inside which is common problem for these vehicles.
If I open the engine for gasket replacement may be possible o-ring, could tell me know precautions to take please?
#1 precaution: Observe all proper tightening torques for all fasteners you need to remove to access the sensor(s), valve cover gasket etc.
Do not attempt any repairs on the engine without the service manual.
I have no idea what "O-Rings inside" are being discussed in the youtube video. Then again, I am no Youtube Certified Master Auto Technician.....
