Headlight range control and adaptive suspension warning lights
Old Apr 21, 2014 | 05:10 PM
  #11
Kebabian's Avatar
Originally Posted by mishar
You need your own VCDS scan in order to know that is the same issue, or what the issue is.
Here's my scan:
Monday,21,April,2014,21:03:41:59303
VAG-COM Version: Release 704.1
Address 55: Xenon Range
Control Module Part Number: 4E0 910 357
Component and/or Version: Pre-AFS H01 0040
Software Coding: 0000001
Work Shop Code: WSC 02311
1 Fault Found:
01310 - Level Control System Control Module (J197)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 192936 km
Time Indication: 0
Date: 2014.04.21
Time: 17:35:32
Monday,21,April,2014,21:04:59:59303
Address 34: Level Control
Control Module Part Number: 4E0 910 553 E
Component and/or Version: LUFTFDR.-CDC H05 4290
Software Coding: 0015510
Work Shop Code: WSC 06133
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 18
Reset counter: 170
Mileage: 192933 km
Time Indication: 0
Date: 2014.04.21
Time: 17:35:28
Old Apr 21, 2014 | 05:26 PM
  #12
mishar's Avatar
Tech Guru
Not the same. His was right and yours is left. Actually no joke. You could spend hours fixing the wrong side.
I don't know the outcome. OP didn't get back and share his knowledge. If he got some.
I would disconnect harness to the left front sensor, clean it and apply some DeoxIT to it.
The other error might disappear when you fix leveling one.
Old Apr 23, 2014 | 08:51 AM
  #13
Kebabian's Avatar
Looked like that did the trick.... After 20 minutes on the road, the fault returned. Is the next step to replace the sensor itself? If so, does anyone have the part number and is it difficult to remove? I wasn't paying too much attention when cleaning the connector, so I didn't notice how it was secured to the axel components.
Old Apr 24, 2014 | 12:08 PM
  #14
Kebabian's Avatar
Any suggestions on whether replacing the sensor should be the next course of action?
Old Apr 28, 2014 | 11:56 AM
  #15
Kebabian's Avatar
Here are the readings from VCDS.... Thoughts?
Old May 15, 2014 | 11:00 AM
  #16
Kebabian's Avatar
For anyone searching the forums and coming across this thread. Replacing the front left level sensor solved the problem. Took 20 minutes. Sensor was 170 USD.
mrandrewjames
Sep 25, 2022 01:11 AM
tony caputo
May 30, 2018 01:38 PM
DISCOSTU29
Suspension Tuning Discussion
Mar 22, 2017 07:44 AM
1SGHHC160
Audi allroad
Oct 16, 2008 03:17 PM
davester0000
Audi allroad
Sep 21, 2004 04:33 PM
