How tough is it to replace Fuel Suction Pump
Not sure is anyone remembers, but I was having issues with my 2004 Audi A8L 4.2L when I got down to about a 1/4 tank of gas, when driving the car would just die. I would coast over to the side of road and turn of ignition and start the car and continue on. This never happened before I had the fuel pumps replaced. Took it back to that shop 3 times and they could not find anything wrong with it. So after a few months I took it to another shop and they said it is the Fuel Suction Pump on the passenger side, but said it was 700.00 to replace. I thought that was expensive since the part was only 150.00 and labor was only 2.4 hours. How hard would it be for a novice to replace this part? Thanks
(3/4 of my post was eaten so I had to come back and edit it....sorry!)
Makes sense that it is the suction pump and not the fuel pump as the suction pump makes sure the fuel pump is always surrounded by fuel under cornering or braking despite the fuel level. From my AllDataDIY guide (worth the
They do have the step by step guide in AllDataDIY. If you can't find it let me know and I'll dig up the link. Took me a few min to find it.
There is no fuel suction pump. Right pump imploys Venturi effect to transfer fuel. It is simple part that can't be broken, only disconnected hose. Check SSP 282 http://www.volkspage.net/technik/ssp/index3_eng.php to see how it works.
There is no fuel suction pump. Right pump imploys Venturi effect to transfer fuel. It is simple part that can't be broken, only disconnected hose. Check SSP 282 VolksPage.Net - Technik - SSP - Self Study Program - VAG - 201 to 300 to see how it works.
D3 was intro'ed in Europe in 2003, but only in 2004 in USA. Thus if a Euro SSP, 2003 date isn't surprising. Notice forum board itself for D3 is labeled as 2003-2010. Tricky part is in Europe a 2003 would be a D3, while in USA they were still end of run D2's. Same issue in 2010's, and issue to come with circa 2017 D4's and D5's.
#4/8 are your Suction Jet "Pumps" with #2/10 being the Fuel Delivery Lines and #3/9 being your Suction Jet Lines. #5 is the Expansion Tank and #17 is another Suction Jet Pipe.
If I understand this correctly the Fuel Pumps themselves (#1/11) suck in gas from the baffle they are located in rather than just tank to make sure they are always surrounded by fuel. This is accomplished by having the Suction Jet Pumps suck in the gas from the tank. They are a venturi pump rather than a mechanical pump.
Back on the same page now?
