Keyless\proximity sensor ,and timekeeping question
Hi guys I have a 2007 S8 with all the options and my car has never unlocked when I walk up close to it like it's supposed do with the key in my pocket I was told that it's possible because somebody used or I should say the last owner installed a cheesy battery and it's not coded properly to the vehicle , or is that the battery voltage is lower than it should be and cuts those options out which is normal but after driving the car for 2 1/2 hours the car should be fully charged in the battery should be perfect and this problem still persists ? Any ideas , also my vehicle has a problem with keeping the time almost every day I have to get in the vehicle and reset the time and date .
It could be the battery is bad or something is not shutting off properly and is draining the battery at night..
1st test the battery.
Fully charge the battery and then see if the keyless works etc.
Then go from there to explore other possibilities
I have had a failing battery lose its ability to start the car even after being on the charger until ready, driving only a mile and trying to start as little as 30 minutes later.
Other simple idea if it is actually only keyless entry and not the main battery is to be sure the car key is not in same pants pocket as your cell phone. They don't get along well together and need to be sent to their own rooms/pockets.
One small point. Mine does not unlock based on proximity- only when I put my hand under the handle does it unlock. I believe this is how they are supposed to operate.
The keyless entry does indeed work only when your fingers are under the door handle, if you have to pull on the handle to unlock it and then pull again to open then the proximity sensor in the door handle is faulty.
Faulty door handles can keep the car awake and flatten the car battery so its worthwhile in my experience keeping on top of door handles and replace them if they are not working as per design.
rfmad
04-07-2014 09:01 AM
