loose TB after tb job
So in December me and a friend mine reputable tech at vw did the tb job on my 06 a8 . We use the continental kit from worldpac all the rollers are made by ntn oem brand. I've been noticing a slight whining noise since the job but couldn't figure out where it was coming from. I took off the belt cover today to my suprise the belt is loose and having too much play on it.
At this point I staring trouble shooting different things. I notice that when you start the car and turn it back off the belt is firm then after a few minutes that's when it gets a lot of play in it so I'm thinking it a the dampner . Any other suggestions?
Good question honestly I would assume he did we did this in December but that noise has been there since we change the tb etc. Anything he was suppose to do special? Like I said guy work at vw and friend of mine I would hope he did it correctly
From your response to Johnny's post, sounds like you need to go back to the guy and ask him what his procedure is. Look on your invoice and see if part A or B were even changed. They are somewhat pricier than other parts so I would not be so sure. Also, not convinced NTN is OES. I put one of their tensioners in my A6 4.2, and later pulled it and threw in garage can when I could see visually it wasn't really square to the front of the block and thus the belt. Got one from dealer at that point.
And, did you change the hydraulic dampener "B" or maybe "cheat" (BTDT...) and not pull the crank pulley to get at it and get it out of there? Also, did you do the specific procedure to tensioning setting where you have that dampener locked off with the pin and then use the gap gauge as part of setting tension per Johnny's post? (I just use the right sized metric allen wrench as the gauge). Likewise that can be hard to get to and not just "guess it" depending on how you approach/avoid the crank pulley pull.
Banned
Yes there is, and check with your friend as MP stated as to parts replaced, also the piece I am referring to has a offset cam adjustment to take up slack in the belt before the tensioner come into play, as MP questioned "Also, did you do the specific procedure to tensioning setting where you have that dampener locked off with the pin and then use the gap gauge as part of setting tension per Johnny's post", as shown in the illustration the locking pin keeps hydraulic tensioner out of play while you tension the belt with offset idler.
Johnny J J
Johnny J J
Johnny J J
Johnny J J
Also, I recall reading that NTN is not OEM quality. However, I could be mistaken.
After buying a kit of parts from the "blue" company which turned out to be junk (others have posted about issues with their so-called quality as well) I will only go with parts in a VW/Audi box that I personally pick up from an Audi dealer. I do not recall an NTN logo on any of the parts I bought from a dealer for my last job. I do know that the "blue" set of junk parts included some items in NTN boxes. I believe the hydraulic tensioner and at least one of the rollers. BUYER BEWARE Especially on safety related or critical, possible engine destroying components such as the timing belt and associated rollers and tensioning components.
[QUOTE=Mister Bally;24698018]One of the camshafts can sometimes move slightly after the engine is stopped thanks to the valve springs pushing on the lifters. This can cause the belt to be loose at some points and tight at others. Now, if the belt is loose everywhere, might want to stop using the vehicle and get the problem corrected.
After buying a kit of parts from the "blue" company which turned out to be junk (others have posted about issues with their so-called quality as well) I will only go with parts in a VW/Audi box that I personally pick up from an Audi dealer. I do not recall an NTN logo on any of the parts I bought from a dealer for my last job. I do know that the "blue" set of junk parts included some items in NTN boxes. I believe the hydraulic tensioner and at least one of the rollers. BUYER BEWARE Especially on safety related or critical, possible engine destroying components such as the timing belt and associated rollers and tensioning components.[/eeQUOTE]
Ok this makes sense like I said the only reason I notice it is because have the covers off. and to clarify what I meant. The belt is not loose all the way around. It's tight just off shutting the engine down. Once I start feeling on the belt and put a lil pressure on it just checking the tension it get a loose only between the two cams (runs under the water pump). Everywhere else on the belt is tight ....base on your explaination this could be normal?
