Need to replace CD Changer needing help...
When I purchased my 2004 Audi A8L the CD changer makes a static noise the whole time I play a CD. It didn't bother me before but now I need to update my MMI to the newest 4610 version so I want to make sure the bad CD Changer won't effect my update and ruin my MMI unit. I am looking to replace the CD Changer and wanted to know what the correct part number was. I've done some research and from what I can tell it looks like the correct part number is 4E0 035 111 A can anyone confirm if that is correct? Also if it is correct and I buy a used one will it just a plug and play or will the component protection kick in? Thanks!
CD changer has Component Protection. It must be removed at a dealer. Newer ones can play MP3. Part number: 4E0 057 110 L. Have you tried to clean your lens and check connection before replacing it?
CD is dead - CD players are being obsoleted!!!
If you're going to spend a few hundred bucks to get a new CD player - I recommend an AMI and a bad battery ipod - The cost may be the same or less, but it is more reliable than the moving CDs inside the changers.
Cheers,
Louis
Cheers,
Louis
If I purchased a used 4E0 057 110 L would it work with my system and since it was used would it still have the CP?
