oil filter cartridge cap
I've done some reading and the "nut" molded to the plastic cap which covers the cartridge housing is a common problem. It gets rounded and won't turn. Solutions include an aluminum "cap" but some concerns about whether it might get seized to the housing. So, I bought a plastic one and will make sure it doesn't get tightened too hard.
My question is not whether to go aluminum or plastic, but how to get the current plastic cap off? Is there room to use a vice grip pliers or will it just squash the nut further? Is there room to put a big old pipe wrench around the top edge of the plastic cap? What about poking a hole in the plastic with a screw driver and use it to turn the cap off?
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Original question???
Now that i have two replies stating the obvious, does anyone have a suggestion on how to get the cap off that the nut has already been rounded. (not by me BTW!)
Hillbilly rig it
Install on the oil filter cap and let it cure. Then back off and discard the cap.
How can anyone strip a big hex nut like this... Amazing
A simple socket would do nicely... so many mechanic imposters out there, it's scary.
Actually, <a href="https://www.amazon.com/Norpro-3-Piece-Jar-Opener-Set/dp/B00BERJNWO/ref=pd_sim_79_4?ie=UTF8&dpID=41L-o8to6fL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&ps c=1&refRID=5B9THCZWN8BXBDTBFAN5" target="_blank">a small rubber jar opener</a> may work.
File 2 opposite sides for a crescent wrench to grab?
Cheers,
<a href="http://www.dognmonkey.com/audi/change-oil-on-audi-a8l-d3.html" target="_blank">Louis</a>
That depends on what you have on hands. Two 1/2" holes for the beginning and then improvise. Careful with the holes not to damage the housing. Or few smaller holes connected and a long chisel in the slot plus a pipe wrench.
I would start with two 1/4" holes, stick two screwdrivers in the holes and turn it loose with a bar. You will likely have to go at it from the wheel well.
You may want to try a small rubber strap wrench, similar to these (like you'd be getting an oil filter off...though I know it's a tight squeeze in that space):
https://www.amazon.com/gp/aw/d/B00K92810A/ref=ox_sc_act_image_1?ie=UTF8&psc=1&smid=A1XKNZSYY CSYX8
Another option is they make these sockets from Metrinch that are designed for metric or sae, but they also work great for rounded-off nuts (which may work for the oil filter cap).
Still like epoxy to hold socket on cap.
Any thoughts?
Any thoughts?
Galco
10
10-27-2015 11:03 PM
ECS Tuning-Audi
02-18-2014 07:59 AM
ECS Tuning-Audi
02-18-2014 07:59 AM
Jonny K
Audi Original "S" Cars
11-09-2008 09:55 AM
