Radiator Stop Leak
Radiator Stop Leak
Anyone tried Radiator Stop Leak? Could be easy fix for small leaks yet concerned if it could clog something...
If anyone used before with good outcome, can you please share brand/model of the Radiator Stop Leak? In Australia we got Nulon brand and generally pretty trustworthy. https://www.nulon.com.au/products/co...lock-stop-leak
I use Prestone. I had a coolant leak on the service record that trips to the dealer and indie shops could not locate. "Coolant residue found on engine cover, could not located leak, no fault at this time" sort of thing.
I noticed some coolant smell.
I dumped in say 3/4 a bottle when I got the car and have not added coolant since. So it does work depending on what is up with the leak.
For D3 days FWIW, the leaks I had in total were: 1. slight leak at heater block hose clamp in first 10K miles that I found after dealer didn't--the dealership owner had car for first few months as his personal ride (marks on cooling bottle were the giveaway--plus service records they were probing. 2. slightly cracked radiator core right near end of 4/50--that I found w/ belly pan pull and Audi replaced w/ brand new under warranty 3. leak at rear overflow hose due to crack dealer likely first caused at the 75K service (I found their kludge splice cover up); I self replaced. Known W12 heat bake issue flagged on forum for some years now. 4. Splitter connection at front radiator hose area--crap plastic that rots; fitting is W12 specific but it may be Audi systematic since same plastic is at the elbow type fittings where the air bleed screws are that we all have 5. One air bleed screw elbow (see #4); 6. Upper hose slight clamp pullback just above (W12) water pump, leading to minor dripping I spotted--again, first during a routine oil change with belly pan pull where it had left the white dry stuff on bottom of pan.
Any of 3-6 would likely not be fixed by stop leak for even mid term. 3-5 would have at least ended up needing an emergency on road patch and several hours wasted (a few owners have posted first person it happened to them). #6 could have blown motor if clamp gave (which was inevitable with time and miles and heat) and not pulled over and flatbedded in first half mile or so. It might have worked--for a while on the radiator in #2 actually--until it really took a **** God knows when. Might have sealed #1, but then the screwdriver it took a minute to turn once I found it by methodical search was a lot more sensible. So, spin the revolver for Russian Roulette. Much worse odds though from my own experience. In at least one, your car may be dead so to speak, and in most of the rest it is either going to the Emergency Room or at least Urgent Care and maybe some bed rest waiting for parts, maybe hundreds of miles from home and/or in 105 degree weather. It may take another year or two, but the preventative real fix would have avoided the high likelihood eventual breakdown result.
Chimney (02-05-2020)
4ever Quattro
08-24-2008 12:44 PM
