Ready to change my upper control arms
#11
AudiWorld Wiseguy
It's not complicated. Just lube the latch mechanisms and cable entry points, and pop open the splitter box and lube the cables in there too. On mine the force required to pop the hood latches is now a fraction of what it was. Doesn't feel like you're straining anything now.
#12
#14
Alright... I did it... Finally
I'm sure there are many ways to get the inside bolt out, but I got the tip from MP4, I didn't remove the shock fork, pry it down with a screw driver and it worked. This is how I did mine. It should take less time now since I know exactly what to do. Hope this help someone who want to do it. The noise and later vibrations while braking...
Cheers,
Louis
Cheers,
Louis
#16
Next video how to...
Timing belt service = how to rebuild bent valves due to broken timing belt... :-) I'm determined to see how far my original engine will go before it pops due to timing belt or tensioner... :-) It's been 2.5 years and 33k miles already... 106k miles... let's see if I will have 120k miles service video... then 135k miles... etc...
Next one will be how to fix my dash board LEDS... broken wire under the arm rest? I don't drive much at night, but will fix it anyway.
Cheers,
Louis
Cheers,
Louis
#17
As I've posted years ago, I felt I could get 150,000 miles out of the OEM belt. But, when the $20.00 thermostat stuck closed in the summer with 120,000 miles on the clock, I replaced everything at that time.
#18
AudiWorld Wiseguy
https://www.audiworld.com/forums/a8-...e-wtf-2616464/
The physical belt itself I also think will last well over 100k miles. I don't however believe the rest of the equally important components that form the overall system will, which is a point many folks seem not to understand. I was planning on doing my timing belt service around 85k, but a stuck thermostat at 76k made the decision for me. Money well spent though. I want to keep the car and for something that fails suddenly and without warning, I'm not prepared to knowingly risk the considerable dangers of me or my family getting stranded and simultaneously putting me seriously out of pocket. All because I made the unwise choice of cheaping out on a bit of scheduled maintenance. Makes zero sense on so many levels that I just don't get some people's seemingly pathological aversion to timing belt services.
Anyway, each to their own and all that.
#19
Yes, to each their own. I inspected my belt thoroughly at 10,000 mile intervals.
As you 've probably seen , the replacement parts did cause a breakdown 1000 miles from home on the July 4th weekend. We were lucky to repair it on the road in 100℉ heat.
It all boils down to money.
#20
This is exactly why I rather to trust the original equipment on my car
Cheers,
Louis
