Speaker wire outputs Bang & Olufsen amp
Hi, I have myself a 2006 S8 with the Bang & Olufsen system. I am wanting to install a Sub/Amp - but am unsure what wires to tap into on either amps in the boot for Hi/Lo converter. My last resort is to tap into the parcel shelf speakers if no one has done a similar install.
Many Thanks.
Many Thanks.
You want to modify a $6500 sound system option that has a fiber optic interface? I think you would be better off equalizing out what you want rather than adding an amp. The B&O is over amped as it is.
If you want excessive bass, well that is another issue. I tried a 2017 S7 with a B&O this last weekend. My D3 A8 with the Bose has better bass response for things like Funk, Motown, etc. than the new B&O. Mostly because of the woofers in the front doors and the Equalization.
If you want more bass, try turning off the surround processing. On the Bose, putting the system into surround mode really kills the deep bass.
If you are hell bent on adding an additional sub, then tapping into the existing sub is your cheapest option. Anything that ties into the MOST network costs in excess of $1000. I looked into an EQ and instantly got a nosebleed from the high prices.
Tailoring the EQ on the B&O is doable, but to really change things, some hacking of the amps firmware may be required. Better have a spare amp before hacking in case you brick an amp.
There is a brown wire with a lime green stripe and brown wire with a royal blue stripe. These are in the harness coming out of the subwoofer amp (one closest to front of car) Those were the two I used on my 2007 S8 with B&O. This is the high level output that goes to the subwoofer.
Good luck!
Good luck!
We used the same output wires to the sub from the amp. We used a LC2 line level adapter but as we learned from experience, install a trigger from an ignition on source. The normal trigger from amp will not work because the class D B&O amp will not keep on the line level converter. You will be very happy with the sound of the B&O with an additional amp.
I am looking forward to adding a sub and a amp on my B&O equipped S8. I am still researching this. Id like to see some pics and write up before i dive in though. I know TSHong posted in one of my threads some pretty detailed info and pics, I'll have to study them.
I am using an LC2 as well and had the same issue with the auto turn on. I struggled to find a switched circuit for the remote turn-on. What did you use? I found one in the fuse box on the passenger side of the dash, but it doesn't shut down until the car goes to sleep.
Thanks, I'll have to check that out. Is there a delay before it turns off after shutting off the ignition? I thought I tested that location and it had power all of the time. I'll have to check again.
