URGENT front end update help needed w12 headlights VAGCOM
#14
Did this today with Liam and still the same result
Matched controller 09 to Liam's 05 w12. still no luck on the headlamps getting power.
So now i am thinking there must be a harness difference.
VAG-COM Version: Release 704.1
Data version: 20070723
Wednesday,17,October,2007,17:17:13:28471
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E15N015342 Mileage: 40690km/25283miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Sporadic communication error 1000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door,Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Coding: 0007773
Shop #: WSC 02313
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - Implausible Signal - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0010 0101
Address 02: Auto Trans Labels: None
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Coding: 0000002
Shop #: WSC 02313
1 Fault Found:
18005 - Powertrain Databus: Missing Message from Level Control System (J197)
P1597 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 40692 km
Time Indication: 0
Date: 2004.04.19
Time: 02:13:16
Freeze Frame:
RPM: 1696 /min
RPM: 1536 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 19.0°C
T.B . Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.LBL
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313
2 Faults Found:
01542 - Yaw Rate Sensor (G202)
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 05: Acc/Start Auth. Labels: None
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Coding: 0410624
Shop #: WSC 02311
Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
01334 - Door Control Module; Rear Right (J398)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:00
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 204
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 202
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.16
Time: 21:14:20
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Coding: 3940448
Shop #: WSC 02313
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.LBL
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Coding: 0000003
Shop #: WSC 02313
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
1 Fault Found:
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 40692 km
Time Indication: 0
Date: 2004.04.19
Time: 02:14:07
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 C
Component: KLIMAAUTOMAT 016 0400
Coding: 1052993
Shop #: WSC 02311
Address 09: Cent. Elect. Labels: 4E0-910-279.LBL
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0133121
Shop #: WSC 02313
Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 202
Mileage: 0 km
Time Indication: 0
01494 - Bulb for Parking Lamps; Left (M1)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:24
01498 - Bulb for Parking Lamps; Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:24
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:24
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:25
Address 0E: Media Player 1 Labels: 4E0-910-111.LBL
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
1 Fault Found:
02095 - Component Protection Active
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 183
Mileage: 40628 km
Time Indication: 0
Date: 2004.04.02
Time: 16:54:12
Address 0F: Digital Radio Labels: 4E0-910-593-XM.LBL
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component:
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 204
Mileage: 40692 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:02
Address 15: Airbags Labels: 4E0-910-655-84.LBL
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Shop #: WSC 02313
2 Faults Found:
01219 - Rear Airbag Igniter; Driver Side (N201)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
Address 16: Steering wheel Labels: 4E0-910-549.LBL
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
Shop #: WSC 02311
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.LBL
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Coding: 0016233
Shop #: WSC 22133
Address 19: CAN Gateway Labels: None
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Coding: FCFE7BDD1B7904
Shop #: WSC 02313
4 Faults Found:
00470 - Combination comfort Databus in Single Wire
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 197
Mileage: 40689 km
Time Indication: 0
Date: 2004.06.23
Time: 11:53:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 40689 km
Time Indication: 0
Date: 2004.06.23
Time: 11:54:58
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 6
Reset counter: 166
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.26
Time: 00:43:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 40692 km
Time Indication: 0
Date: 2004.04.19
Time: 02:13:16
Address 25: Immobilizer Labels: None
Coding: 0410624
Shop #: WSC 02311
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 204
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 202
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.16
Time: 21:14:20
Address 34: Level Control Labels: 4E0-910-553.LBL
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 02313
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071530
Shop #: WSC 02313
Address 37: Navigation Labels: 4E0-910-88x-37.LBL
Part No SW: 4E0 910 888 C HW: 4E0 919 887 C
Component: MNS US H44 0960
3 Faults Found:
02261 - Media Player; Position 1 (R118)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 2
Reset counter: 201
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 23:40:25
Freeze Frame:
Hex Value: 0x4072
Hex Value: 0x16E2
Hex Value: 0xFA10
Hex Value: 0xF000
03183 - Unknown Error Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 27
Reset counter: 166
Mileage: 40626 km
Time Indication: 0
Date: 2004.04.02
Time: 16:08:34
Freeze Frame:
Hex Value: 0x4088
Hex Value: 0x9191
Hex Value: 0x0303
02927 - DVD Read Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 204
Mileage: 40690 km
Time Indication: 0
Date: 2004.04.05
Time: 23:02:21
Freeze Frame:
Hex Value: 0x407C
Hex Value: 0xD307
Address 38: Roof Electronics Labels: 4E0-910-135.LBL
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Coding: 0003477
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 205
Mileage: 40692 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:00
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028204
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:12
Address 46: Central Conv. Labels: 4E0-910-289.LBL
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Coding: 0065086
Shop #: WSC 02313
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 205
Mileage: 40689 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:04
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 166
Mileage: 15739 km
Time Indication: 0
Date: 2006.01.10
Time: 12:59:40
Address 47: Sound System Labels: 4E0-910-223.LBL
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Coding: 0000016
Shop #: WSC 02313
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Coding: 0010111
Shop #: WSC 02313
1 Fault Found:
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 86
Reset counter: 166
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:21:00
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0028204
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:12
Address 53: Parking Brake Labels: None
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Coding: 0000532
Shop #: WSC 02313
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000004
Shop #: WSC 02311
3 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40696 km
Time Indication: 0
Date: 2004.04.23
Time: 03:31:09
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40696 km
Time Indication: 0
Date: 2004.04.23
Time: 03:31:09
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40696 km
Time Indication: 0
Date: 2004.04.23
Time: 03:31:09
Address 56: Radio Labels: 4E0-910-541.LBL
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Coding: 0000002
Shop #: WSC 02313
Address 61: Battery Regul. Labels: 4E0-910-181.LBL
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Part No: 4E0 915 105 A
Component: von VA0 1502140363
Coding: 344530393135313035412056413031353032313430333633
Shop #: WSC 00000
4 Faults Found:
02273 - Rest Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Mileage: 39390 km
Time Indication: 0
Date: 2004.03.25
Time: 00:18:45
02276 - Rest Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 50
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:28:12
02274 - Rest Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 50
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:28:22
02277 - Rest Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 47
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:28:32
Address 62: Door,Rear Left Labels: 4E0-910-802.LBL
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028204
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:12
Address 65: Tire Pressure Labels: 4E0-910-273.LBL
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0280
Coding: 0232125
Shop #: WSC 22133
1 Fault Found:
00003 - Control Module
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 29807 km
Time Indication: 0
Date: 2006.08.31
Time: 13:57:37
Freeze Frame:
Speed: 0.0 km/h
Voltage: 13.30 V
(no units): 11.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.LBL
Part No SW: 4E0 910 753 S HW: 4E0 035 753 A
Component: SDS 3501 US H45 0550
Address 72: Door, Rear Right Labels: 4E0-910-802.LBL
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028204
Shop #: WSC 02311
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 197
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:53:44
01482 - Motors for Central Locking
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.17
Time: 04:38:18
02130 - Interior Door Lighting
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 14
Reset counter: 166
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.17
Time: 04:46:54
02127 - Exterior Door Handle Light / Mirror Light
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 166
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.17
Time: 04:49:32
00379 - Terminal 58s
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.19
Time: 02:14:10
Address 76: Park Assist Labels: 4E0-910-283.LBL
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Coding: 0001208
Shop #: WSC 02313
5 Faults Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:41:33
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:41:33
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:41:33
02070 - Rear Parking Aid Sensors
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:25
02069 - Front Parking Aid Sensors
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:25
Address 77: Telephone Labels: 4E0-910-336.LBL
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Coding: 0010900
Shop #: WSC 02313
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 202
Mileage: 40692 km
Time Indication: 0
Date: 2004.03.29
Time: 02:23:07
End --------------------------------------------------------------------------------------------------
Chassis Type: 4E0
Coding: 0007773
Shop #: WSC 02313
2 Faults Found:
Coding: 0000002
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 40692 km
Time Indication: 0
Date: 2004.04.19
Time: 02:13:16
Freeze Frame:
RPM: 1696 /min
RPM: 1536 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 19.0°C
T.B . Angle: 0.0°
Coding: 0008597
Shop #: WSC 02313
2 Faults Found:
Coding: 0410624
Shop #: WSC 02311
Component: ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 204
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 202
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.16
Time: 21:14:20
Coding: 3940448
Shop #: WSC 02313
Coding: 0000003
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 40692 km
Time Indication: 0
Date: 2004.04.19
Time: 02:14:07
Coding: 1052993
Shop #: WSC 02311
Coding: 0133121
Shop #: WSC 02313
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 202
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40693 km
Time Indication: 0
Date: 2004.04.23
Time: 03:45:25
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 183
Mileage: 40628 km
Time Indication: 0
Date: 2004.04.02
Time: 16:54:12
Component:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 204
Mileage: 40692 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:02
Coding: 0530707
Shop #: WSC 02313
2 Faults Found:
Coding: 0012141
Shop #: WSC 02311
Coding: 0016233
Shop #: WSC 22133
Shop #: WSC 02313
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 197
Mileage: 40689 km
Time Indication: 0
Date: 2004.06.23
Time: 11:53:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 40689 km
Time Indication: 0
Date: 2004.06.23
Time: 11:54:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 166
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.26
Time: 00:43:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 40692 km
Time Indication: 0
Date: 2004.04.19
Time: 02:13:16
Coding: 0410624
Shop #: WSC 02311
Component: ELV XXXX
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 204
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 202
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.16
Time: 21:14:20
Coding: 0015510
Shop #: WSC 02313
Coding: 4071530
Shop #: WSC 02313
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 201
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 23:40:25
Freeze Frame:
Hex Value: 0x4072
Hex Value: 0x16E2
Hex Value: 0xFA10
Hex Value: 0xF000
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 27
Reset counter: 166
Mileage: 40626 km
Time Indication: 0
Date: 2004.04.02
Time: 16:08:34
Freeze Frame:
Hex Value: 0x4088
Hex Value: 0x9191
Hex Value: 0x0303
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 204
Mileage: 40690 km
Time Indication: 0
Date: 2004.04.05
Time: 23:02:21
Freeze Frame:
Hex Value: 0x407C
Hex Value: 0xD307
Coding: 0003477
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 205
Mileage: 40692 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:00
Coding: 0028204
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:12
Coding: 0065086
Shop #: WSC 02313
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 205
Mileage: 40689 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:04
Freeze Frame:
Fault Priority: 3
Reset counter: 166
Mileage: 15739 km
Time Indication: 0
Date: 2006.01.10
Time: 12:59:40
Coding: 0000016
Shop #: WSC 02313
Coding: 0010111
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 86
Reset counter: 166
Mileage: 40688 km
Time Indication: 0
Date: 2004.03.25
Time: 02:21:00
Coding: 0028204
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:12
Coding: 0000532
Shop #: WSC 02313
Coding: 0000004
Shop #: WSC 02311
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40696 km
Time Indication: 0
Date: 2004.04.23
Time: 03:31:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40696 km
Time Indication: 0
Date: 2004.04.23
Time: 03:31:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 40696 km
Time Indication: 0
Date: 2004.04.23
Time: 03:31:09
Coding: 0000002
Shop #: WSC 02313
Shop #: WSC 00000
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 53
Mileage: 39390 km
Time Indication: 0
Date: 2004.03.25
Time: 00:18:45
Freeze Frame:
Fault Priority: 7
Fault Frequency: 50
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:28:12
Freeze Frame:
Fault Priority: 7
Fault Frequency: 50
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:28:22
Freeze Frame:
Fault Priority: 7
Fault Frequency: 47
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:28:32
Coding: 0028204
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:55:12
Coding: 0232125
Shop #: WSC 22133
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 29807 km
Time Indication: 0
Date: 2006.08.31
Time: 13:57:37
Freeze Frame:
Speed: 0.0 km/h
Voltage: 13.30 V
(no units): 11.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028204
Shop #: WSC 02311
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 197
Mileage: 40688 km
Time Indication: 0
Date: 2004.06.23
Time: 11:53:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.17
Time: 04:38:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 166
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.17
Time: 04:46:54
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 166
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.17
Time: 04:49:32
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 205
Mileage: 40688 km
Time Indication: 0
Date: 2004.04.19
Time: 02:14:10
Coding: 0001208
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:41:33
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:41:33
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 04:41:33
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:25
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 40690 km
Time Indication: 0
Date: 2004.03.25
Time: 02:22:25
Coding: 0010900
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 202
Mileage: 40692 km
Time Indication: 0
Date: 2004.03.29
Time: 02:23:07
#16
already pulled it from bentley publishers. Came up the same with the same doc
Pulled both cars a8 and w12. Downloaded the Headlights with High Intensity Gas Discharge (HID) ' Bi-Xenon ' lamps and Automatic Headlight Beam Adjusting Wiring Diagrams. This produced the same document.
Here it is.
<a href="http://smg.photobucket.com/albums/v332/ima****er/?action=view¤t=Picture5.png"><img src="http://img.photobucket.com/albums/v332/ima****er/Picture5.png" border="0" /></a>
Here it is.
garfield1973
VAG-COM Discussion
01-20-2008 08:11 AM
Jack Wang
VAG-COM Discussion
02-17-2007 12:13 PM
Acceler8
VAG-COM Discussion
04-22-2006 07:54 AM
