Sponsored by:
Sponsored by:
W12 Exhaust
Old 11-19-2009, 08:03 AM
cpbetts's Avatar
Default W12 Exhaust
Hi,
The exhaust system on the A8L W12 consists four tailpipes but al low engine speeds only two are active. The other two open when full throttle is actuated.
My question is can the flaps in the exhaust be made to remain open all of the time.....in effect increasing the exhaust note )
thanks
chris
Old 11-19-2009, 09:18 AM
Essate's Avatar
Yes, just remove the flaps.
Old 11-20-2009, 10:13 PM
MP4.2+6.0's Avatar
Default Don't remove the flaps...
they are integral with the rear muffler. Instead just pull the vacuum hoses that control them and cap those off. Presto, the valves are permanently open since they are designed to "fail" in that position if something goes wrong.
Old 11-25-2009, 02:02 AM
cpbetts's Avatar
wonderful, that worked a treat
many thanks
Old 03-30-2013, 03:07 PM
RenoRanes's Avatar
I know this is a very old thread but I'm trying to do exactly this.
I've pulled the hoses off each side however the flaps remain closed, is there something else I need to do to actually get them to open and stay open?
Thanks.
Old 03-30-2013, 03:28 PM
MP4.2+6.0's Avatar
Default Should be open...
If you pull the hoses on a U.S. W12, they stay open all the time. IIRC, folks w/ some S8's have occasionally reported they apparently stay closed as the default position. Perhaps non U.S. set up is different or even varies by year.
Old 03-30-2013, 04:39 PM
4ringking's Avatar
S8 default to open with no vacuum... I have installed a few Milltek Sport Systems on the D3 S8s and all have been the same.
Now Porsche vehicles, those can be tricky...
Old 03-30-2013, 05:56 PM
EHLO's Avatar
My US specification 2008 S8 with the stock exhaust defaults to closed with no vacuum.
I had to pin them open.
Old 03-30-2013, 06:02 PM
zedbyers's Avatar
Pin? I had a Z06 and there was a fuse you could pull that would keep them open. A fella named Lou Gigliotti came up with a gear shifter that had a button wired back to the fuse box so you could open/close at will.
Interested in figuring this out as I purchased a S8 this weekend.......
Old 03-30-2013, 06:25 PM
EHLO's Avatar
Yes, I used hooks to pin the valves open, which normally are closed under spring pressure at low RPM when not acted on by vacuum.
Quick Reply: W12 Exhaust
