2012 Audi A8 MMI visible only for a few seconds after screen comes up
#11
Once you have the display removed it is much easier to disconnect the power lead. You can try to repair the lead or buy a used one from ebay and splice it in. The signal wire is the larger diameter coaxial cable (yellow writing in your picture). My power lead had an intermittent connection, so I just jumpered it to another source, Should be a simple fix for you, taking the dash apart was the hard part.
#13
Turns out it was power to the screen, not sure why. Possible bad wiring, but I couldn't dig far enough to see it. I tapped into another source and solved my problem, sort of. The two micro switches I thought were related to the power issue I couldn't figure out, one is broken so I thought for sure that was the culprit, except it wasn't. So now both switches have been removed, screen works fine. I thought they would control the motor for fully raised or lowered, but it seems to do that just fine without them.
#14
blank monitor repair
I cut the other power wire as you suggested which allowed me to pull the housing out further to unplug the AV cable and another bunch of wires from the mmi housing motor and was then able to pull the mmi housing far enough out to unplug the pin connector housing that the power wires run into. The pin connector housing (part number 3D0972708) just unplugs from the bottom of the mmi display screen, I needed to use tiny flat blade screw drivers to unclip it from the screen. Now that the wire housing connector is out I could remove the wire pins. The repair part number is 000979009E, when it arrives I will cut it in half and insert each end into the connector housing then splice to the power wires and put it all back together.
#15
That didn't work for me. The only other thing I could ascertain is that the monitor doesn't work. I wish I knew how to test the monitor by itself. In addition after removing my front panels to get to the radio my air bag light came on.... So now I have to find out how to reset that!
#16
#17
Turns out I can see a yellow connection in one of my pictures....that is probably an airbag. So I may have disconnected it, I didn't unplug the battery and cycled power numerous times during my testing. I also have VCDS so if I had a light, I reset it.
audiworld2
Q7 MK 1 Discussion
10
02-25-2020 07:38 AM
2fst4u2c
50
09-20-2007 05:51 AM
Hornet
07-31-2002 05:10 AM
