A8 front rotors 356mm v 380mm
#12
Mine just turned 45k miles. I checked the rears and the surface definitely does not need replacement, but I don't know about the "warping"
Audi said 3mm left on front and 4mm on rear pads.
I have the sport edition, so based on AllData, these have 380mm rotors, rears at 356mm. (I also measured to confirm)
I've sourced the OEM rotors & pads, and my brother has access to a lift, so thinking I can get this done myself.
AudiParts.Com : $1356
AudiUSAParts.com: $1513 (shipping made this much more expensive)
FCPEuro.com $830 ???? With lifetime guarantee?? (guarantee includes rotors!) aeggroup, I noticed your ebay posting looks like the same as FCPEuro, but if you buy from them, it's guaranteed for life.
https://www.fcpeuro.com/page/lifetime-guarantee
Anyone think the FCPEuro these would be an acceptable option?
Here is a link for the front kit. https://www.fcpeuro.com/products/clo...at-4h0615301an
Thanks for all the help
#13
#14
Yes, FCP's warranty covers rotors and pads. The catch is you have to mail them back to FCP in order to get your account credited.
I've used their warranty before on a rear strut and control arm.
Good luck.
Good luck.
#15
I went to a 3rd party Audi repair shop yesterday to check to see if they would do the labor on the brakes. They said sure. The service tech said it's $500 because it requires a "special" tool.. Price was not toooo bad, but I"m laughing about the special tool. It's just the VCDS/Vag-Com to unlock the parking brake.
Parts are ordered from FCPEuro. With tax & shipping, $907 for 4 rotors, pads & sensors. Zimmerman rotors & Akebono ceramic pads. Not bad if I do say so myself.
#16
Just a heads up, the front brakes on a 2015 A8L are EASY!! Tires off, 2 bolts holding the calipers, 1 nut holding the rotor, 1 nut holding a cover that holds a spring. THAT'S IT..
After I worked through the first one, the other side took me less than 1/2 hour.
It took me longer to do the break in.(for the second wheel) (30 separate brake operations 100km-> 50km, then 100km -> 25km with 3 minutes in between for cooling).
My only difficulty was removing the rotor. Rusted/frozen in place. I tried a plastic/rubber hammer, a regular hammer, then a sledge hammer .. The last hammer worked. I added anti-seize on the hub so that the next time it might be easier.
If anyone is questioning if they should do this, and you have some basic mechanical skills, I would definitely recommend doing it yourself.
Thanks for all the advice and help, saved me about $1800
TinyElviss (06-27-2019)
oskidunker
10
08-24-2019 07:14 AM
fatty711
02-25-2004 10:43 AM
ticotino
01-19-2003 09:27 AM
