Additional tune up items?
#11
I hear you. I have never had any issue with K&N but I know some have. Usually problems can come from users over-oiling them and fouling the MAF.
This is one I purchased. I have used them in the past with good success. Cleenaire CAF667
Much better and cheaper for me: just pull std. filter out mid cycle and blow it out with air. On W12 with 40K cycle, would just do that every other oil change for the tweener one. Current Audi designs are very straight in (and efficient for cold air), but they also then eat more leaves, bugs, road crap, etc. Will do same on S8 at 20K and then 60K. Yours is 60K cycle. Factory is then disassembly and about 2 minutes air time instead of: oil, mess, newspaper, overnight to try to get off extra (oiling it right...), etc.
#12
Any comments on what oil these engines like? Or specifically the 3.0? I have used mobile 1 extended performance for years with good results. I was noticing others using mobile ones 0w - 40 European formula. PUP is also great oil but it's never in stock when I head to the store.
#13
Short version: Mobil1 0W40 as most common; NO other common Mobil 1 typically acceptable. Or Castrol Edge 5W40 US as possible closest proxy to dealer oil. Many others to but MUST meet specific VW/Audi spec.
So, first thing you need to know is the 502/505 VW oil spec. Your post says as a subtle matter to be sure to be able to recognize it. That is required for any Audi gas motor in USA to meet spec. If under warranty and you don't run it, that can punch the warranty when it most counts--internal motor nightmare. They are literally known to run oil analyses these days in suspect situations and that seem oil related and if it comes up wrong, bill can be on you.
Fortunately the list is long. It's on the Audi USA web site, and I have posted link several times. Your post is why I also say to get familiar with the spec. Thus, Mobil1 0W40 European Formula meets the 502 spec, but almost no other Mobil 1 common shelf version does, in any viscosity. There are a few corner cases, but none of the common like 10W40, 5W30, etc. So, forget any other easy to find grade you may have used (ESP is only other footnote BTW for 504/507 discussion below). Mobil1 0W40 is probably the most common go-to cited on the boards, though there are always the fans of some of the specialty brands out there. Mobil 1 can be found in jugs these days, periodic sales, WallyWorld, Amazon, etc. Not Costco though in that viscosity.
I checked and the fill they ran the A8 3.0T motor on in the EPA tests was 5W40 in 502 spec. Basically that is standard USA dealer fill, though they actually have been certifying the 4.0T's on a different oil and spec in recent years. More specifically, at the dealers it is usually Castrol Professional Grade, in 5W40. 4.0T is spec'ed for that too, even if not necessarily factory fill. Can't buy that label on average store shelf, though keep reading...
If you want 5W40, another choice also found pretty easily is Castrol Edge 5W40US. May well be the dealer oil, just without the uV dye in the Professional Grades they use Euro dealer channels. Again, if motor blows up in nightmare scenario but then either has their dealer change service history and/or they see the uV dye, end of any questions about oil type. Castrol also have a 0W40 and OW30 marked European Formula that is 502/505, but harder to find.
Many more, but those are some. Post AudiCare/off warranty, historically I have run Mobil 1 0W40 most of time, both on C5 4.2 and D3 W12. At 115K miles D3 W12 still burned not even a small fraction of a quart on full 10K change cycles. Literally only time I put any in was for the change itself. FWIW, as I sneak some tweener changes in and transition Q5 off AudiCare, for the hell of it I recently bought both some 502/505 oil and some 504/507 from audiusaparts. I paid in mid $5 range/qt. for a couple cases of the 5W40, and a few more for 504/507. Mid $5qt. is getting close to jug price for Mobil1 discounted, and there is no 504/507 oil out there for at least several dollars more than I paid from any normal source. 504/507 is for S8, but that's a whole separate discussion and even state dependent for some technical (fuel) reasons. Dealers still think of 504/507 as basically for diesels meantime, plus pricier and not what Audi factory put into 3.0T anyway nor that dealers use in general with gas motors.
#14
MP, any experience with PUP's 0w40.
https://www.amazon.com/gp/aw/d/B00JMCCE6U/ref=mp_s_a_1_1?ie=UTF8&qid=1489030595&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=penzoil+ultra+platinum+0w40&dpPl=1&dpID=51pVRs9ZdlL&ref=plSrch
Think I found that link you were talking about.
https://www.audiusa.com/content/dam/...e-Bulletin.pdf
![https://www.amazon.com/gp/aw/d/B00JMCCE6U/ref=mp_s_a_1_1?ie=UTF8&qid=1489030595&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=penzoil+ultra+platinum+0w40&dpPl=1&dpID=51pVRs9ZdlL&ref=plSrch](https://www.audiworld.com/forums/images/misc/amazon_icon.gif)
#15
https://www.amazon.com/gp/aw/d/B00JM...dlL&ref=plSrch
#17
How about oil filters, are you sticking with OEM Mahl? They have a great reputation and I don't really see a need to deviate.
Link
Link
Same application, audiusaparts: Oil Filter for 2014 Audi A8 Quattro|06E-115-562-C : Audi Wholesale OEM Parts - Audi Genuine Accessories - AudiUSAParts.com e-Store $12.29. $13.37 on Amazon. Some though reasonable shipping cost for a given order vs. Amazon Prime, but then no sales tax in whatever the state set up is and same two days distant from me. No big deal here, but illustrates on dealer/OES parts for tune ups, discounted dealer in my experience has become fully competitive. That's how they price typical tune up/consumable parts these days. Not the "dealer rip" reputation folks often want to believe. There are several of these dealers scattered around country with a decent web presence and selling at discount, depending on exactly where you are if shipping time is important.
S8 4.0T dealer filter (also cartridge) is unmarked BTW for others. On D3 W12 it was a cartridge in Hengst. On Q5 2.0T it is a spin on "MHO," which I think is Mann's abbreviation for extended name of Mann+Hummel. In that 3.0T filter picture, a little fuzzy but I think it says Mann.
If you want to go another direction, or suddenly need one same day locally for a job, FWIW I often find a Purolator store boxed filter has the OES one inside. Looked on shelf a few weeks ago and they had the S8 one, which looks same as one I have in hand. My old A6 4.2 had spin ones which were Manns. Bought a dozen Purolators on eBay for $4 each that set me up for life; Purolator sticker on the typical Mann black spin on, with all the Mann silk screen printing right there too. $48, 120K miles, just add oil.
Francisco -Altenio Diaz
A4 (B7 Platform) Discussion
07-28-2018 02:38 PM
Ben's e//S2
03-15-2006 06:58 AM
matt719
08-22-2005 08:01 PM
mmart6545
07-26-2004 09:32 PM
mladen
11-10-2002 05:37 PM
