Aftermarket Brakes?
#31
Posted on the rotors sort of endlessly now, so search. Patented design most likely, so no other suppliers. Size used with arguably higher volume SQ5 too, so it's not that is just some one off fitment. Design of rotor also probably answers why reluctant to turn. Somewhat floating on pins. Years ago friend with M6 where these first appeared was declined by an indy machine shop for turning them, saying they couldn't hold surface stable when tool was applied to it.
#32
I use OEM Textar on my E46M3. Friction rating varies.
Don't really get the 4.0T point either on checking. Old internet echo's? TireRack let down?
My check showed essentially all the same ones again. Basically all but Hawk--which isn't real high on my own list for ceramics anyway. Thus, EBC in Green, Red and Yellow, Porterfields, Carbotechs in all the flavors, Disc Italias and others on the Brakeworld site.
Then add Textar's--might be the OE since found on Audi's sometimes; on ECS site. Also even Ate has a front 4.0T listing now. Probably more too; I think the old lore of no 4.0T pad support is sort of out window. Makes sense, since my own experience with a new fitment is it can take 3 or 4 years for common names to get product out there when they start to anticipate aftermarket sales. Saw it with the D3 S8 and W12 fitment which was new when I first had the W12.
#33
Also falls into a pay me 1x now or 5x later bucket (can?) to me. That is, from 35 years wrenching experience on Audi's, first or second best diagnostic you can do is get under there periodically and give it a good look see for leaks and damage. (Other one is VCDS.) Oil extractor = laziness tool to avoid getting under there said most bluntly, but for a reason. What you don't see/want to avoid can then hurt you. Leak in a vehicle with hydraulic power steering can go from a $50 bill for loose clamp stuff, to hundreds for hose, to $2500 for pump if run dry of fluid and burns up in in as little as 15 minutes of further run time trying to get home or to repair shop. Or, leak found in radiator core for me on W12 cost me nothing but time to spot and bring it in for warranty full replace. It was a pinhole type that just would burn off with no drip. If pan were always in place and slight wetness never spotted, maybe two years later in 105 degree weather at side of road? Motor risk? And $500 ish parts cost and another $500+ to install? Said more at altitude, simply seeing presence of any leaked fluid either underneath or on pan surface is actually one of the greatest "free" diagnostic tools out there. Only cost is...time to remove it, which happens for any oil change done "old way" but not with out of sight out of mind extractor "shortcut."
Pay me 1x now via old school oil change or 5x later for the other missed stuff...
#34
I've done this on all my cars...some easier than ø†hers.
BMW easy...the oil filter cartridge is accessible from top.
Audi C5-4.2V8s, I use amsoil (fair disclosure lifetime amsoil dealer) changing 8-10K miles with full flow oil filter change every other oil change. Yeah, I hate getting under the car to snake out that big/long oil filter øn the C5 4.2.
#35
I am getting ready to do my brakes before long. My rears are in the need more then the fronts but I am leaning towards doing them all at the same time. I would like to do the work myself. Is there a good tutorial out there for the D4? Everything seems pretty straightforward but its nice to have a good DIY for reference. I have been searching without any success. I do have VCDS.
#36
once you try it and take off the calipers everything will be pretty obvious.
#37
probably not much out there for this car since there arent too many out there to begin with and people on forums for something like the a8 is extremely rare. seems like only 5 guys on here for the a8/s8 lol. either way doing brakes are easy...if you have done it to any car before then its always the same essentially...only difference could be some clips or screws that hold the pads in place.
#38
Update. Installed my Centric Posi-Quiet pads and rotors on the back. Front OEM are still in decent shape but I will probably put Centric pads on the front soon. Nice and smooth and quiet. They are great pads for typical daily driver. Looking forward to seeing how well the rotors last with these. Working on getting the dealer that CPO'd my car to now replace or refurbish my wheels. Happy I was able to cancel AudiCare Plus too. What a ripoff that would have been. Hopefully this will all work out for me. Little patience and persistence.
Fast Euro
11
12-12-2006 01:44 PM
Front Brakes/Rotors What to get...Nothing too expensive just replacing OEM, for rotors i want.......
S40RCE:Smurf
04-09-2006 07:42 AM
