Audi A8 4H 2011 - soft close (power latch) retrofit
Hello everyone,
I want to retrofit a soft close (power latch) system on an A8 4H and I need help with coding the door control module . I started with the front passenger side door , all parts are in place , all wiring done ... I just need to recode the door control module . The part number is 4H0959792F , adress 52 , current coding 011D12205E00628202080002 .
If anybody has an Audi A8 4H or VW Touareg 7P with soft close please give me your coding for the passenger side door control unit.
Thank you.
Thank you.
Mine is:
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0166
Revision: -------- Serial number: 0000120382709
Coding: 011F1F205E0062C202000007
Shop #: WSC 02312 785 00200
VCID: 3A7138C4B544B89
No fault code found.
I'm hoping Ross Tech will have the 4H page up soon....
Edit:
According to the 4E coding it's +4096 but that doesn't make sense based on what mine says.
Coding
+0000001 = Insulated Glass installed (PR-4KV/4KS)
+0000002 = Right Hand Steering (PR-L0R)
+0000004 = Lighting Package (Interior Lighting - PR-QQ1/QQ3)
+0000008 = Lighting Package (Exterior Lighting - PR-QQ2/QQ3)
+0000016 = Synchronous Mirror Adjustment
+0000032 = Air Recirculation Closing active
+0000064 = Electrical Child Safety Lock (PR-GZ2)
+0000128 = Electrical Side Shades installed (PR-3Y8)
+0000256 = Safe Function enabled (PR-A8S)
+0000512 = Folding Mirror installed (PR-6XE/6XF/6XK/6XL/6XS)
+0001024 = Automatic Dimming Mirror installed (PR-6XJ/6XK/6XL/6XM/6XS)
+0002048 = Pinch Protection active
+0004096 = Closing Assistance (PR-GZ2)
+0008192 = Seat Memory Driver installed (PR-3PN)
+0016384 = Seat Memory Passenger installed (PR-3PN)
+0032768 = Child Safety Lock disabled with Door Open
Edit:
Coding
Thanks for your answer. I will try your coding first thing in the morning. There are a few bits that are different on your coding , I presume you have more options related to this door module than this A8 has. I will try them one by one until I find out which is the bit (bits) I'm looking for.
Regarding the old (4E) A8 , the coding for the door modules was done on 2 bytes (decimal number up to 65536), for the 4H it's done on 11 bytes (a lot more options I guess). I don't know how soon the Ross Tech page will have details on the 4H , not even the latest VAS software (May 2012) can code this module without online connection to Audi SVM.
I will let you know how it goes, thanks again.
Hi again ,
After a couple of hours of trying different coding variants starting from the coding you gave me I have to report it's not working. I thought I made a mistake in the wiring but then I checked Measuring blocks group 008 - Power latch position , optional extra .
Measured value block 008:
Readout 01:
Power latch position (optional extra)
(n. fitted/unpressed/close/back)
Readout 02:
Power latch motor current consumption
(current consumption readout in [A])
Readout 03:
Status display
xxxxxxxx (0=not active/1=active)
87654321
xxxxxxx1: Door open
xxxxxx1x: Catch contact closed
xxxxx1xx: Return-stop-contact closed
xxxx1xxx: Child lock
xxx1xxxx: Power latch has detected blocking current
xx1xxxxx: El. child lock engaged
x1xxxxxx: Not used
1xxxxxxx: Not used
Readout 04:
Power latch fault display
87654321
xxxxxxx1: Power latch fault catch
xxxxxx1x: Power latch fault door contact
xxxxx1xx: Power latch fault motor
xxxx1xxx: Not used
xxx1xxxx: Not used
xx1xxxxx: Power latch fault return stop sticking (close)
x1xxxxxx: Power latch fault return stop sticking (open)
1xxxxxxx: Not used
Values 1,2 and 4 are Not installed for me, with every variant of coding (I even tryed your whole code). Could you confirm that you have something other than Not installed in these blocks ?
Readout 01:
Readout 02:
Readout 03:
Status display
87654321
xxxxxxx1: Door open
x1xxxxxx: Not used
1xxxxxxx: Not used
Readout 04:
87654321
xxxx1xxx: Not used
xxx1xxxx: Not used
1xxxxxxx: Not used
I'd be happy to look, but it's going to be a week or two before time permits.
You might want to ask on the VCDS Yahoo group for a faster response.
Thanks-Jake
Thanks-Jake
Ok , thanks. I will try on the Yahoo Group. If you have a saved Autoscan of your car please give me your coding for modules 05, 09, 42 (it's probably identical to 52), 46 and 62 (or 72). I'm starting to think that another module needs to be recoded. Mine are :
Address 05: Acc/Start Auth. (J393) Labels: None
Part No SW: 4H0 907 064 BB HW: 4H0 907 064 AB
Component: BCM2 2.0 H23 0333
Revision: 00002001
Coding: 05A72F00000000000000
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000681971
Coding: 26002010C034AFE18B810007E0001D0C0F9CC3088601012180 0008402000
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000108801272
Coding: 011D12205E00628202080002
Address 46: Central Conv. (J393) Labels: None
Revision: 00002001 Serial number: 0136980406
Coding: 011A0E2000B97485A320C7C40A010000000000000000000000 0000000000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000107447033
Coding: 010D12204000628202080002
Thank you, I owe you a couple of beers for all the trouble .
Revision: 00002001
Audi A8 4H Soft Close (power latch)
Hello,
Did you ever get this to work - I have it on my 2011 A8 but am trading up to a new one (ex demo) and although it has every feature under the sun it is missing this wonderful feature which I love. I could be really cheeky and "borrow" the parts off the old one before I sell it.
Hello,
I am also interested how you did it?
Can you give some hints?
Thanks
4RINGkingA8L
01-04-2013 09:02 PM
x1rider
15
11-24-2007 02:45 AM
