"HELP", S8 Engine Failure, 58k miles, 2012
#11
Also watch the possible faulty windshield seal near inside center mirror on any early D4. Obvious if it pees water, awkwardly in rain or a car wash, or opportunistically if you hose test it with towel at the ready. That one merits a recall, but I bet Audi is trying to bury it.
#12
Tunes in a turbo 4.0 running that hard on the throttle for that length of time is never going to be foolproof. "Stuff" happens fast under big boost. One little bit of deto will take pistons out, either holing them or taking out ring lands or even breaking the rings and valves too, when it happens it will waste the turbo impellers as you have carnage running thru the turbos.
Even with the best detonation protections in place it happens. I've seen the best Motec ignitions and injection stuff in the world not save an engine from a bit of overboost or poor fuel. There is a reason the factory only pushes them so far. If you add HP, you have to be prepared to pay the price. There is an obvious reason the factory will not warranty a "tuned" ECU vehicle. Its easy to crank up the boost and power, its also easy to blow them up when put into the hands of the uneducated public that knows nothing about boost, intake temps, octane and fuel quality and all its other workings on the subject.
#15
Coolant issue on 4.2 leads to flaky electrical stuff and wiped out ECU worst case IIRC. Search archives if needed. By chance see this couple year old thread for example that resurrected again today: https://www.audiworld.com/forums/a8-...acing-2888829/
Most common A/C issue is probably that refrigerant needs to be replenished; best by professionals. Need it on my D3 by 7-8 years, and was back to perfect with that.
#16
They are going to be fixing the AC today they said
#17
Yeah I brought up that old thread today hoping some other people will chime in. Flaky electrical stuff and wiped out ECU sounds really bad to me but I also do not know much. I assume that wouldnt be covered by Audi for a 7 year old car that has 50k miles and I will be the 3rd owner.
Needless to say, Audi says as little as possible about the emissions warranties even pre Dieselgate. I doubt many ever try to make a claim that way unless a state emissions station gives someone the exact "how to" roadmap.
#18
final update. car fixed
both turbos were badly damaged. one side the propeller had fallen down the down the down pipe the other one was just rattling about like a straw in a coke can if that makes sense. no bits got into the engine. 2 new turbos all in 100% fixed at a cost of £5500. unit 20 audi specialist UK England would highly recommend for any repair.
https://www.unit20.com
Paul99SE
08-06-2000 12:59 PM
