Sponsored by:
Sponsored by:
Residual heating
Old 12-11-2018, 12:13 AM
davey_b's Avatar
Default Residual heating
Discovered the other day that if the car is off and you hold down the fan button for a couple of seconds the car will be heated with the residual heat from the coolant for an hour. Not tried it for that long but I have used it a few times when I've driven somewhere, got out to do something for 10 - 15 minutes and left it on (with the car off and doors locked) and come back in and it's still nice and toasty and blowing warm air. Nice little feature that some other folks might not know about.
Old 12-11-2018, 03:26 AM
Twglasgow's Avatar
TinyElviss knew
Strange2C (01-19-2024)
Old 12-11-2018, 04:32 AM
Kelzo's Avatar
Does this work with the a/c as well?
Will have to try the heat today...being below freezing and all.
Old 12-11-2018, 04:38 AM
Jibsymalone's Avatar
No it won't work with the A/C as the engine needs to be running to run the compressor. In heat all it does is circulate the hot coolant through your heater core and run the fan all of which can be done on battery power....
Old 12-11-2018, 04:49 AM
D4 in PA
TinyElviss's Avatar
When you engage the feature, you can also adjust the fan speed. Mine defaults to 3.
It will run up to 30 minutes, so in the interest of battery life I turn my fan speed down to 1 if it's going to be running for the entire cycle. Still keeps the car toasty!
Old 12-11-2018, 07:57 PM
chris355's Avatar
Great tip everyone. Tried it today while waiting in drive through lane at pharmacy. Works like a charm.
Old 12-12-2018, 04:31 AM
Moderator
virtualrc's Avatar
Nice tip. Thanks for posting.
Old 12-14-2018, 02:22 PM
SWelsch's Avatar
Best tip of the year. Thanks!
Old 01-16-2024, 09:41 AM
andrewbrion's Avatar
After nearly 7 years of ownership I finally discovered this. I had been using this feature on the Q7 for years, but never realized that it works on the D4. It has come in very handy the last week in Minnesota!
Old 01-16-2024, 10:30 AM
W12 Aficionado
2turbos4rings's Avatar
Worked all the way back to the D2
davey_b (01-17-2024)
Quick Reply: Residual heating
