audi 100 electrical problem
i have some issue with my 91 audi (4 speed auto)
water temp guage,fuel guage,radio,don't work.Also i can't take off antilock light out.Help i check fuses they are all in good shape
Re: audi 100 electrical problem
Component: ELECTRICAL SYSTEM
Summary: SHORT IN ELECTRICAL SYSTEM, CAUSING COMPUTER/GAS GAUGE/WARNING BUZZER/RADIO TO FAIL. *AK
This is a costumer complaint from NHTSA and seems similar to your problems. Does your car stall at times? Most electrical problems in Audis 91-97 are a result of defective ignition switches; about 9 out of 10 are defective. Audi makes the worst ignition switches and have been redesigned at least a dozen times and they still are not good. Also, it does not matter if it is black or a white ignition switch too b/c both have have failed in the past.
Have you tested the brakes to actually know if ABS is not working. ABS relay or no-continuity in the abs wire running from (front vehicle along drivers side frame to back seat ABS module) could be the cause. The ABS module itself could be faulty. I would not attempt the wiring unless you know the electrical system well enough.
Brad
Playerseightball@aol.com<ul><li><a href="http://nhtsa.gov/">http://nhtsa.gov/</a</li></ul>
Brad
golfnthroop
07-15-2010 10:51 AM
donaldp
03-16-2010 07:34 PM
kinderutz
Audi Original "S" Cars
07-25-2007 10:57 AM
qc100
Audi 100 / A6 (C4 Platform)
03-28-2002 08:07 AM
