Audi won't move
Audi won't move
Hi I have problem it begine when my front stability bar it what ever long bar slipped from it spot. Broke cv joint outter. Well now I was driving and suddenly I hear klonk and suddently car moves but won't speed up and we'll I towed it back and take out cv axel and pitted car neutral and turned car on and saw that pice in gear box was rotating. And link to transmission works for sure it feels like it goes in to gear may it be inner cv joint or outer? That locks up transmission? Or somthing your thoughts?
Sounds like your sway bar came loose...You need to investigate and find out why.
The sway bar holds the lower control arm in place..if it comes loose..the axle/CV joints will break when the lower control arm swings back. With a broken CV..the car is immobilized..
Could be the rubber bushes at the end of the sway bars pulled out or the end nut is loose. Get that checked and then look for a new axle or new CV joints and rebuild the axle.
Yes it was sway bar that came lose I fixed it and changed outer cv joint and drove for 100km total I heard loud snap and car won't accelerate but moves freely I'm thinking that it may be inner cv joint or agen outer cv joint+ it may be other side that snapped possible?
Probably the inner CV has given out..when the sway bar breaks or comes loose it really hurts both CV joints..the outer and inner. Your new outer CV should be okay..I would remove the axle completely and inspect both.
Discovery
Today I pulled other side of axel out and tryed pr your thing in transmission well dident come off But other side comes out just pulling out
Are Im missing teeth or I'm missing O ring I cant see it should it come with it?. And what is part called??
Forgot to add I turned my car on both sides spin when in neutral meaning my transmission fine?? Spins when no axels meaning
That is an axle flange..normally no need to remove this part. Just remove the CV joints bolts on the flange and remove the axle. The flange stays on the transmission. I have attached a page from the repair manual. Your problem is in the CV joints?
