Buying advice needed!!! Thanks.
I was looking into a 97 Audi A6 quattro wagon,
81000miles.
Just did the mechanic check, they told me it has leak in right front strut, minor leak at rear differential, oil cooler O-ring leaks.
The deal now is $9750, do you guys think it is a good deal?
How much will be needed to repair those leaks?
Thanks a lot!
81000miles.
Thanks a lot!
I'd talk him down to around $9K at least...
You'll want to replace both front struts together. That's around $150 in parts and probably 1-2 hours/side in labor and then an alignment. Rear diff seals, cheap parts maybe another 1-2 hours labor. Not quite sure about the other stuff. S4Master can probably tell you though.
Thanks!Re: I'd talk him down to around $9K at least...
Seems replacing struts will cost around $500,
the seller claims that he is also a mechanic and
he told me that replacking both will only cost 1 hour, seems he was not telling the truth.
Thanks a lot ck100q.
