Closing windows with the key
Check to see if someone took out that fuse. It's sort of a thermal relay, not a fuse.
The "all close" is controled by a circuit in the vacuum pump located next to your battery. It's burried in foam so the pump noise doesn't carry into the car. For those of us who had battery drain, the solution was to disable the function by cutting a yellow wire.
Because of the problems I had drawing current. I removed that fuse and it produced the same results as yours. So, somewhere the 12 volts that is supposed to travel through that fuse is not getting to all the window motors it should.
