Different Brand Tires On a Quattro
A friend told me that using different brand tires on a quattro can be a problem. For example, I just wanted to buy two new fronts, Fulken 115's, and leave the good Pirelli P7000's on the rear. I don't see an issue. Am I missing something by installing very similar type tires though differnt brands? Thanks.
It can be bad, depending on sizing issues...
...different manufacterers have slightly different definitions of what a mm is . As long as they are substantially identical in design and size, you should be ok.
QCrazy's defintely right there..
..and more on the sizing issue: hen you have different sized tires on a Quattro (even slightly) or any 4 wheel drive vehicle, it's almost like running different sized tires on the right side and left side of a 2wd vehicle. The radius of the tires is different, therefore the rotating circumfrence is different...i.e., you end up with different distances for the tire to travel one exact rotation. This inherently causes different torques on either side of the driveline, causing irregular wear on the driveline parts which = a very long weekend on your back looking at driveshaft parts.. doh!!
Billy_Madison (12-10-2019)
Re: QCrazy's defintely right there..
Thanks.
Both tires have very similar tread patterns (uni. also) and perhaps the Fulken is a mm wider than the P7000's (both are 235/40-17's)? I didn't see any bigger issue than having pretty worn tires on the back and new ones on the front and all the same tire brand and spec.
Ultimately I want to get away from the Pirellis but have many miles left on the rears and prefer not to dish out another $300.
Re: Different Brand Tires On a Quattro
You can not use different size/brand tires from side to side on a Quattro because of the Torsen Differentials. You can use different size (same size different brand) front to rear. This is talked about in the owners manual.
Your friend is thinking of a car like a Subaru that uses a Viscous center differential, in which case you can not use different size/brand tires front to rear.
And of course as the others mentioned it is always best to use 4 of the same tires. If you rotate your tires regularly you won't end up with two worn out tires and two good ones.
That doesn't really make sense to me....
Side to side has NO bearing on the Torsen differential. (There's only one in these cars) Front to back would make more since but side to side does not.
If the owners manual does state what you say it would not be becasue of the Torsen diff.
Anyway, it's just a bad idea. Don't be so cheap :-)
Who came up with the tale that putting odd matched tires on quattro will ruin something in the drive
RedBlackYellow
02-08-2006 12:23 PM
UCLABruin4life
Wheels & Tires Discussion
12-19-2004 08:54 PM
B7Quattro Pete
12-20-2002 03:25 PM
Is it true that since we have quattro - the tires do not wear out as much? -for only those who know!
GiVmEaUdI
06-28-2002 08:25 PM
