Minor tranny leak in '96 A6 FWD Avant - Suggestions...
The auto trans in my '96 A6 has a minor leak in the area immediately above the cats, at the very rear of the trans (the area above the transmission pan). It doesn't appear to be a bad pan gasket nor any leak in the power steering rack dribbling down the firewall. The car has slightly more than 44K pampered miles, and runs/shifts no differently than the day I bought it nearly new. The trans was serviced last August (fluid change) IAW the maintenance schedule. I have done a search on the forum, but have only found threads on quattro versions (e.g., rear transmission shaft seal) or power steering rack leaks.
Before I dismantle the cats/exhaust or haul it to the shop, I thought I would solicit suggestions on the forum. The Bentley Repair manual doesn't provide much guidance in the area either. Has any body w/ a FWD version of the 2.8L automatic had a similar problem? Thanks.
Every Audi that I have worked on seems to have that problem....
Normally it seems to come from on of the lines to the tranny. Mine has been that way for four years and I have never fixed it. It always appears wet but it never drips and I don't loose any fluid so I have just left it alone.
Thanks for the info. My minor leak appears to follow your experience. One possibility....
that appears to be the source is the shift lever shaft seal. Have you ever had one on these transmissions out of the car & noticed any fluid around that shaft? Without dropping the cats/exhaust system, I really can't inspect that area. But judging from the dirt/grime buildup (i.e., a long time w/ a very small amount of fluid), it would appear that the amount of fluid is very minor and does not readily leak additional fluid. Might just become a regular annual maintenance item to clean away the grime and live with it.
dan4g63
15
05-24-2023 04:13 PM
sochi
Audi 100 / A6 (C4 Platform)
10-02-2004 09:23 PM
HamrenDan
11-17-2003 10:22 AM
HenryK
06-24-2002 06:18 AM
