one of the bulbs on my dashboard is out...
sometimes when i bang it it goes back on. then the next day it stays off. any ideas. is it hard to change the bulbs? its a 97 a6q.. any input will be appreciated, thanks
Two screws under the bottom cover of the dash, pull the cover towards you and left.
You'll access three screws hoding the dash; unscrew them. Pull the steering wheel down and back to allow the dash to come out. Protect steering wheel with a cloth, otherwise it might get scratched. You might be able to replace the bulbs without disconnecting the brackets.
bulb cost $4 from dealer. FAQ inside should have some info on the procedure.
Different wattage of bulb is coded with different color. I think you need bulbs with orange plastic base.
You can get the (8) background bulbs for ~$1.25 ea. I used Jahn 1.2W bulbs (p/n 1641)....
Removing the IC is fair easy, just take your time and pay attention to unplugging/disconnecting all of the wiring (if this is your first attempt). To remove the two large connectors (the red and green connectors), pry up the center U-shaped lock, and then unplug. When you re-install the wiring, check that you have them all in before reinserting the IC into its cavity. Then test all of the lights/gauges/indicators by starting the engine and checking the operation. Then re-install the 3 screws, and then the lower trim/screws. Since I have done this a few times, I am able to remove the IC in 5 - 10 minutes time.
THANKS TO ALL OF YOU FOR YOUR HELP....
you guys make everything so easy!!! i did it and it took only 25 minutes. i have to get the bulbs today. i did notice that the turn signal bulb does not work, the one on the right. i took it out and maybe i did not put it back right, does anyone know the type of bulb thats used for the turn signal, i am speaking of the turn signal on the dashboard. its a blue based bulb??
thanks again
thanks again
Be careful.. do not turn on the ignition when the cluster is out...
Because the computer thinks that the air bag bulb is out and will store a error code and then you will se that the airbag light will take about 2-3 minutes to go off after starting the car. I made this mistake... you will then need a Vag Com to clear the codes
germanmissile
03-02-2005 02:11 PM
slook
10-01-2001 07:55 AM
