Sun Roof Water Channel Repair Question
<center><img src="http://pictureposter.audiworld.com/29555/rainchannel.1.jpg"></center><p>I searched the forum & found many of you have fixed the stupid designed water channel attachment brackets. After my wife came home today & said the sunroof leaked into her pocketbook, I found my rattling sunroof shade problem...I can't see a way to repair these other than J B Weld with the unit in the car. According to the Bentley manual it doesn't look like a bad job to replace the channel with a new one. The book says you must remove the glass roof panel which looks like a 15-30 minuet job & the rest is a piece of cake. These parts remind me of the supports for the sunroof on my type 44. Audi did revise the design & make a stronger replacement part for them. Please let me know your thoughts & opinions on how I should repair this.
And does anything attach to the eyelet @ the rear of the thing?
Devcon 9394
Which is an Aerospace epoxy. Once dry, its will be stronger then the aluminum its glued too! ;O)
The key is surface prep, cure temps & time.<ul><li><a href="http://www.devcon.com/worldwideframe.html">http://www.devcon.com/worldwideframe.html</a</li></ul>
Re: Devcon 9394 Help
Thanks for the link. I can't find an adhesive or epoxy you refer to with that number on the site the numbers may have changed. Is the material:
Aluminum Putty F (10610)or one of the epoxies like Metal Welder(14366)?
how did you take that out i have no clue how to take it out to fix it...
mine in my S6 has been broke jjust like that for at least a year and a half now and i still can't stand the rattle.
It was loose in the roof cavity I needed to...
Hook onto it with a piece of wire to pull it out once I got in line with where it is to be attached to the sliding panel I slid the sun shade front & it just slipped out on an angle. If I fix to out of the car I will be hard to put it back in. Being able to have it out will just help in preparing it for cement or epoxy. Unless someone suggests I remove the small riveted bracket off to fix it then screw them back on.
<ul><li><a href="http://msds.ogden.disa.mil/msds/owa/web_msds.display?imsdsnr=9394">http://msds.ogden.disa.mil/msds/owa/web_msds.display?imsdsnr=9394</a</li></ul>
One of these May Be It
<center><img src="http://www.devcon.com/prodimages/P59.jpg"></center><p>
Please let me know which of these three 5 minute epoxys are the closest to what you used. Thanks in advance!
http://www.devcon.com/prodimages/P58.jpg<ul><li><a href="http://www.devcon.com/prodimages/5MinFR.JPG">http://www.devcon.com/prodimages/5MinFR.JPG</a</li></ul>
I heard this ones good-
<center><img src="http://www.devcon.com/prodimages/P64.jpg"></center><p><ul><li><a href="http://www.devcon.com/devconfamilyproduct.cfm?familyid=179.0&catid=3 8">http://www.devcon.com/devconfamilyproduct.cfm?familyid=179.0&catid=3 8</a</li></ul>
Ordered... I'll Follow Up After The Repair Is Complete
<center><img src="http://store5.yimg.com/I/aftosa-test_1765_11154921"></center><p>
<ul><li><a href="http://store5.yimg.com/I/aftosa-test_1765_11252739">http://store5.yimg.com/I/aftosa-test_1765_11252739</a</li></ul>
