Windows Roll up randomly
The windows also work with the car off, you can operate them up and down and the sunroof with the key off. Not right, lol. This seems to be accompanied by a battery draw. Sometimes its dead overnight, sometimes is fine for a week. When the car is dead, it usually has enough juice to turn the interior lights on, and you can hear this relay clicking under the dash over and over
Automatic Window Closing Relay, J261 right next to the window controller, i replaced it too, still does it.
I take it out, and use a test light, the power to it is on, off, on, off, just like the clicking. The load reduction relay seems fine. Could this be an ignition switch issue?? Some other control module is failed? Cruise doesn't work either if it could possibly be related.
Its my 92 100 CS
After the car is shut off and the keys taken out, the windows can still be rolled up or down UNTIL the doors are opened. Once the doors are open they shouldn't roll, only with the turned key in the ignition.
