Dash lights work, but have issues
A mechanic had done a cheap wiring job to fix the driving lights but it was a mess.
Ive recently re wired everything back to original stock wiring and replaced the headlight switch and dimmer switch. both were melted. Now i have all my lights back to normal.
But here is a few remaining issues.
#1: when i turn the light switch to both settings 1 or 2 i have all the lights but no rev counter.
#2: when i turn the lights out, i have a rev counter again, but no dash lights or tail lights/running lights.
#3: when i turn the headlight dimmer down to almost off, the rev counter comes back on, but its not correct. It shows that the engine is resting at 300 rpm when its actually at 950 rpm
so basically, it seems as if the dimmer switch along with the headlight switch has controll of the rev counter somehow.
and my dash lights are seriously dim, could someone send spares? i just need the two little blue bulbs that stick into the rear of the instrument cluster
my headlight switch is a little wonkey too, getting the guage lights and runners to work that is. maybe I shoud replace it before it gets worse. . .
