Ignition switch (keyed lock cylinder) R&R.... any BTDT's?
Ok... search didn't help much..... all I could find was how to rekey your door locks and removing the electrical portion of the ignition switch.
Well, my key unit is causing me problems. Doesn't seem to be a bad cut, as it works perfectly in all the doors, and worked fine in the ignition up until a week ago. Now, you put the key in, and fiddle with it until it turns.
So, how do I pull the lock cylinder out? Is there a drill point? The only bentley I've got is a Fox bentley... and as similar as the lock units look, I figured it wasn't the same drill-point.
Heck... I can't even go to a push-button start, cause I still need to remove the lock cylinder to prevent steering wheel lock.
Ok.... checked.... Part number Question....
Ok... here's how it works out:
Fox:
housing - 155 905 851
lock - 411 905 855
switch - 111 905 865
4kq:
lock - 893 905 855
So.... I can't figure it out... whats the difference in locks? I forget what the difference is in the first 3 numbers.... 411 vs 893?
The only reason I'm going this route is because I have several fox parts cars with perfect switches, and being able to swap housings while I get a new switch would be nice.
Anyone have any insight into the difference between part numbers?
Fox:
lock - 411 905 855
4kq:
lock - 893 905 855
brogdan
09-10-2018 05:57 AM
El Desamparado
Audi Original "S" Cars
10-12-2006 06:14 PM
hoov
9
07-19-2004 03:50 PM
pwrstroker300
02-14-2004 04:54 PM
