Ok to drill bolt out of strut housing? no luck with heat, fork, pressure..etc.
I ask because it is that tapered little @#$% so I wasnt sure if i needed to worry about damaged some special thing inside it
You can try it with the fork....
and while applying pressure, get a BFH and hit hard on the strut housing around where the stud goes in. Should pop right out. Douse it with WD-40 or something equivelant first.
Gear puller, or "Proper Tool"..
I've used a tool like this before. It makes tierod removal (almost!) a painless procedure..
<img src="http://www.bmwe34.net/E34main/Maintenance/Suspension/Data/tie_rod_puller.jpg">
But even a gear puller (perhaps combined with a slight bit of pounding) is better than nothing!
fmstocco
9
12-23-2009 04:13 AM
PartyBoyRacing
16
12-26-2008 08:48 PM
JJMcWank
06-02-2006 04:01 PM
