Subframe mounts, question
Upon reading about them on the 90 forum, I think it would be a good investment to replace them when I do my MC swap. Sound like a good idea?
Ive never dealt with the subframe, are the mounts difficult to replace? Keep in mind, I wont have the engine in there!
Will my suspension alignment be off after I replace them? Any "special" tools needed?
Mike
Mike
Re: Subframe mounts, question
pretty easy.... i took my whole subframe off with the control arms attached. You have to jack the car up.... disconnect the ball joints and sway bar... and undo all 4 subframe bolts.... on the cgt one of the mounts is shared by the tranny mount thing. I used a tool simular to huw's site (i think that was it)... a threaded rod and some plumbing stuff that looked about right... to push the old mounts out and press the new ones in. dunno about the alignment... mine still runs straight. once they are pressed in just put it all back together. might also be a good time to replace ball joints and control arm bushings if yours are beat.... hope that was a bit helpfull...
Jared
Jared
Good info, thanks Jared
I figured it wouldnt be too bad. Ball joints and control arm bushings are fairly new, so Im safe there. Subframe mounts would be a good idea while the engine is out, more money to spend, blah.
Mike
Mike
Not sure...just looked at ETKA
Looks to be the trans mount, which I have, and 2 other mounts on the other side, but both have different PN's. Does this sound correct?
Mike
Mike
here is what I have in my notes
shown are PN and quantity.
> 857 199 415 B[4]
front subframe front mounts and rear subframe rear mounts
> 857 199 419 C[2]
rear subframe front mounts
> 857 199 419 B[2]
front subframe rear mounts
Seems like last time I checked, they were dealer items and $40+ each. Could be a little off on the price, but they weren't giving them away.
Let me know what you find out.
> 857 199 415 B[4]
> 857 199 419 C[2]
> 857 199 419 B[2]
heh, actually
You could probably drop the subframe, engine and tranny all as one unit. Might be easier going through the bottom rather then the top. I remember we had an old Mercedes and that is how we swapped the engines. We just dropped the whole front subframe assembly.
First we got to make sure everything is disconnected from the body and the rest of the car. Then we put it up on the lift and raised it up enough to get jacks under the subframe. We then lowered the car enough so the the subframe was resting on the jack stands. The car was body was supported by the body seams which are strong enough to hold. We then unbolted the four subfram mount bolts and slowly raised the car off the subframe. Once the car was up high enough, we we able to put the tires back on, because the axles were still attached, and get a jack under the engine and rolled it out from under the lift.
Once we got it to an open arear, we were able to get it all apart, used a hoist to lift the engine off the subframe and put the new one on. Once that was all together we rolled the subframe back under the car on the jack stands. Then we lowered the car slowly back down and using the jack and muscle to line everything back up. We installed new mounts, bolted it up and once it was in, we were able to reconnect everything pretty easily.
There were two of us doing this and I think it will be best to have at least two doing it.
