Thermostat replace--how bad is it?
Thinking of buying an '84 GT Coupe with bad thermostat. Mechanic said it's a bad thermostat, engine is overheating. Can't find a manual quick enough before I go over with my tools. Can anyone tell me is it deep under a lot of stuff, or is it essentially at the place where the radiator hose goes to the top of the engine? Also where's the radiator cap, I didn't see one? Thanks in advance, tripleD
He said thermo, not cap
The thermo is very accessible, it's on the driver's side of the block near the front. I think the housing has two bolts that hold it on.
You'll have to drain the system and refill it, and then bleed the air out of it (fill the little fitting on top of the rad after you burp it a few times).
Piece of cake....
There are two bolts that mount the cover over the thermostat. they are metric and somewhere between 10 and 13mm ( can't remember off hand)and once you take them out the thermostat is right under. just make sure you drain the coolant out first ( you can remove the lower hose off the radiator) and make sure to replace the o-ring gasket at the same time. it's just behind and under the power steering pump but easily accessable.
Re: is this the car in SF with the overheat problem you are looking at?
well, I sent a buddy to look at it for parts. That car doesnt have what I need..
seems like a good deal I suppose although from what I hear it needs some attention.
let me know how it goes!
jim
jim
NJRoadFan
08-27-2008 02:05 PM
Trick_A6
05-17-2004 03:08 PM
