200q Display
I know this has been a long topic and I've been researching the archives as much as possible (and found the info on SJM)..however, just wanted to throw it out there before digging into the dash...
IC - Display and Trip computer are out (no lights at all). All gauges work fine though. Turn signal stalk / light stalk do not affect the dash as I've read. I've seen a few threads on this particular issue, but none of them posted resolutions. Most other threads seemed to be the Stalk issue High beam dim, etc (related to trunk wiring)..
Is there anything diffrent that I should check before pulling the IC and verifying the solder connections? I will check license plate light and glove box but I believe they are both working.
Also does anyone have inventory of # of bulbs & Type to replace since I'd be in there? I was on SJM and bulbs were like $7 a piece! Autohauz has them for a buck but not sure if they are the OE and what I would need.
Thanks!
