Are aftermarket crank sensors junk?
My 1988 5000CSTQ refused to restart last night after sitting for ten minutes. I determined that there was no spark, coil had power, but no signal from the ECU to the coil. I allowed the engine to cool and it started immediately and ran fine. Cold start today was fine. My diagnosis: the crank position sensor is failing.
Since both the crank position and crank speed sensors are right next to each other and both appear to be the originals, I should probably replace both at the same time. The part numbers are
crank speed sensor: "034 905 381 A" grey in color
crank position sensor: "034 905 381" black in color
According to previous posts, they are identical except for color.
It appears that the two genuine Bosch sensors will cost me over $300(!) for both if purchased through regular vendors.
A Google search of the part numbers reveals that there are vendors who sell non-branded aftermarket sensors for $40 each. I'm tempted to try them, but would like to hear from you guys first. What do you think -- is it it worth trying the non-branded aftermarket sensors? have you tried them?
Here's a typical vendor:
http://www.naautoparts.com/m8_view_i...34%20905%20381
selfproclaimedv8buff
09-06-2007 04:05 PM
Snow Trooper
14
08-22-2007 05:59 PM
snowman '92 100
Audi 100 / A6 (C4 Platform)
10
11-26-2003 11:12 AM
Ofeelya
08-01-2003 08:22 PM
