changed the hall, still not much luck /:
So i installed a brand new hall(the old hall was broken into 100s of pieces... weird?) Installed everything properly, thought I had lined the distributor gear to exactly where it was. Got rapid pulses from the coil wire but the car didnt start (timing off?), played with the timing a bit, tried to restart, Nothing! Checked spark from the coil No spark! Pulled the codes got 2113 (bad hall again?) Will the timing effect whether there's a spark or not? Maybe it's off by a couple teeth?
Thanks
Thanks
Andrew Andrew Andrew!!!!
when will you ever learn. The crank signal and the hall signal must be in sync before the ECU will send a trigger signal to the coil.
<img src="http://pictureposter.audiworld.com/36396/audi-timing.jpg">
New Hall Sensor source?
Hi Andrew,
I had an intermittent problem similar to yours - mine is still unresolved, but I know that the Hall is reading out of range in the window. (Sorry I can't be of much help) Where did you get the new sensor?
Cheers!
Cheers!
It runs It runs It runs!!!!
That was the problem, it was 180 degrees out of synch, woops... well it started right up and I finally have a car again, don't have to drive my brothers maxima around. She needs many other things ofcourse but atleast she runs!
Re: New Hall Sensor source? (Revised)
I saw this on another forum some time ago and saved the picture, but I don't remember if it was for a 10v or 20v engine.
(revised)
It is for a 10v engine.
<img src="http://pictureposter.audiworld.com/36396/audi-hallsensor.jpg"><ul><li><a href="http://store.yahoo.com/classicgarage/au40quco50pi.html">New Hall sensor source</a></li></ul>
(revised)
AutoUnion0000
03-15-2009 05:24 AM
quattrocoach
11-07-2008 06:01 AM
