My car wont run
My car wont run
been stumbly lately. All the ignition stuff has been checked.Filter is good and so is the pump and the screen on it. Pulled ISV plug off idled at 1800rpm but ran. Figured ISV clogged. Pulled ISV cleaned ISV now NOTHING. A very slight catch on two or three cylinders once and they NOTHING but cranking WTF. This is makin me mad. Now when I unplug the ISV makes no difference. any ideas. I checked for vacuum leaks already btw.
WTF?!!?!!?!
WTF?!!?!!?!
Crank for 5 secs, leave key on and pull codes
By inserting the fuse in the FP Relay.
Leave in for 5 secs and pull out the fuse.
Once a code is complete then re-insert the fuse and leave in for 5 secs to go to the next code...
Repeat until all code are gotten.
Post codes, even if 4444.
Also check the super basic.
FP fuse (#15 I think)
MAC-14 Engine ECU Fuses (listed as Motor/Motuer)
strange error code: said "fuse" for 4 secs then disappeared n' now the clock n date are changed.....
slvrbullit
05-06-2001 02:18 PM
