oil cap...good or bad
so the v8 is running a little better. I still get a burning oil smell somewhat sometimes. I looked at the engine to see if I could see fresh oil and it looked like it was coming from the oil cap. Could this be? How can I tell if the cap is bad. Never heard of an oil cap going bad. If it is bad then how can i fix it.
would this fix the valve gasket on a 92 v8 + a new oil cap?
<ul><li><a href="http://www.autohausaz.com/search/product.aspx?sid=4gxtkm45t42spd45yxoil145&make id=800002@Audi&modelid=1009448@V8%20Quattro&am p;year=1992&cid=valve%20gasket@valve%20gasket& amp;gid=5500@Valve%20Cover%20Gasket%20Set">http://
Is it leaking from the valve cover?
& no way you could get a burnt oil smell from a bad oil cap gasket! The oil from the cap would run into the lower intake cover...no were near the exhaust.
But a leaky VC gasket is in the area of the exhaust header/intermitant pipe.
& here's the link to the oil cap.<ul><li><a href="http://www.autohausaz.com/search/product.aspx?sid=iydpu1uktktmoufk2zmcjujd&make id=800002@Audi&modelid=1009448@V8%20QUATTRO%20 &year=1992&cid=20@Engine%20Parts,%20Seals% 20%26%20Gaskets&gid=5269@Oil%20Filler%20Cap">h
pictures - BWW, large images within
I have all of this saved as an .html file with step-by-step procedures and hints and tips and such if you want me to email the .zip to you. I was thinking of doing a whole website full of these but a few problems arose: a) I have no web host, b) I'd always forget to take pictures during repair procedures and c) the Knowledge Base (now defunct) did the same basic thing. I modeled it after the 944 community of <a href="http://www.clarks-garage.com/shop-manual/repair-procedure-index3.htm">Clark's Garage.</a>
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step1.jpg">
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step2.jpg">
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step3.jpg">
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step4.jpg">
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step5.jpg">
YOU ONLY NEED TO LOOSEN THIS FUEL FITTING to wiggle the line out of the way to remove the valve cover.
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step6.jpg">
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step7.jpg">
<img src="http://i10.photobucket.com/albums/a143/indischrot/audi/valve%20cover/step8.jpg">
bar1
Audi Original "S" Cars
09-23-2005 12:04 PM
OneThirtyEight
06-26-2004 05:56 AM
coocoomike
03-01-2003 08:23 AM
