steering rack R&R
Old May 17, 2011 | 12:44 PM
ourv12's Avatar
Default steering rack R&R
Any good write ups on r&r of the power steering rack for a 1993 quattro v8?
Old May 18, 2011 | 08:02 AM
Kneale Brownson's Avatar
Tech Guru
Audifans.com info pages are down.
Here's some stuff on earlier type 44 steering rack removals:
http://classic-web.archive.org/web/2...ler/steer.html
What I recall regarding V8 differences (you still go through the passenger side wheelwell, connections are basically the same), you may need to remove the passenger side distributor to get adequate clearance. You also may have to LOOSEN (not remove) the subframe to lower the tranny a bit too. Or maybe that eliminates the need to remove the distributor. At 70+ the old memory sort of muddies.
Old May 18, 2011 | 10:32 AM
itsav8's Avatar
Worst time i ever had was a rack removal on my old 93. the short R&R description is everything gets removed from the rear of the motor,
dizzy's, coolant hard lines, ect.....
remove bolts for steering damper and tie rod end rods (at rack)
Disconnect bracket at the end of the steering rod inside the car.
Comes out the pass side tie rod opening.
Have fun.
Bloodred86
May 27, 2007 04:09 PM
shwndh
Aug 26, 2006 07:14 PM
PorpShow
May 17, 2006 03:58 PM
Hoof Hearted
Oct 14, 2005 06:23 AM
jaykray
Jan 12, 2005 11:25 AM
