knocking in steering rack
Old May 8, 2006 | 02:21 PM
PorpShow's Avatar
New Member
Default knocking in steering rack
I've started hearing knocking sounds in my suspension. The outer tie rods were loose, so I replaced them. Still hearing occasional clunking, so I replaced the inner tie rods today. The clunking is still there. If I shake a wheel front to back, the inner tie rod will move, and I still have the knocking when driving. Is the rack bad? or is it another part of the steering linkage?
Old May 17, 2006 | 03:58 PM
zapco98's Avatar
Member
Default Re: knocking in steering rack
Its most likely the bolts that hold you're steering rack in. There are two within your firewall, one will require you to remove the battery, its a 10m, and the other top, reachable one is near the brake booster. The third is under the car and reachable with an extension.
ourv12
May 18, 2011 10:32 AM
S4ptld
Sep 22, 2007 06:48 AM
Hoof Hearted
Oct 14, 2005 06:23 AM
jaykray
Jan 12, 2005 11:25 AM
90/90Qs
Jul 1, 2004 06:23 AM
