Wheels FS...
Wheels FS...
<center><img src="http://pictureposter.audiworld.com/4612/dscf0056.jpg"></center><p>Thought I'd give you guys first dibs...
These are 16x7 35mm A8 reps made by ATP.
These are in very good shape with some minor scratches.
I can't promise that they're 100% straight but I've never had any problems getting them balanced.
Would make a good setup for winter tires, etc.
These will fit 91 200 20vt with no problems. To mount on a 5000/200 you may have to flare the rear fender or go with a smaller than 55 sidewall profile(205/50/16 MIGHT fit)
I ran these on my 5ktq with 205/55/16's and slight fender flaring without rubbing problems.
$300 OBO. LMK if you're interested. You pay shipping.
Wheels come with Audi and ATP center caps, hub centric rings and lugbolts.
Steve
Michigan
Steve
Michigan
I have the OEM version of this...
rim on my 86 5kcstq. I run 205/55/16's and have no fender rubbing issues. The only thing that may be different is the offset. Does any one know the offset of the stock A8 rim? Just currious.
Re: I think 38mm.
So does that mean the stockers are set inward a little more? Wich would cause the rubbing with 35mm? Just want to get my facts straight, offset has always confused me a little. Thanx.
Stockers are 45mm offset...
which means they are set "in" a bit.
The lesser the offset, the farther out the wheel will protrude.
It gets tight at 35mm on a lowered car.
Steve
Michigan
Steve
Michigan
pgauntt
06-18-2006 06:07 AM
ShoppingKartRacer
Audi 100 / A6 (C4 Platform)
09-18-2002 01:13 PM
