2 Questions!
2 Questions!
How hard is it to get the starter out of an 88 80Q? Any PITA things I should be aware of?
What about for a Coupe Quattro?
Basically- I need to take the starter from the 80 and put it in the CQ so i can drive it for now because ice flew off of the back of a tractor/trailer and almost came threw the windshield of my CGT. And the best part is... They arent liable for it!!!
1 question
how are they not liable for it? that sounds like a b.s. deal. I know around here they "aren't liable" for dump truck type debris, but is this the same case?
Yep... 2 bolts...
The bottom bolt goes through the starter/block/transmission and is a bolt/nut. Can be accessed from under the car.
IIRC it's a 17mm
Top bolt comes through from the transmission side, and threads into a hole in the starter. Easiest way to get to it:
-pull the battery out
-pull the little 'panel' out of the bottom of the battery tray
-reach down in with a wrench or socket+short extension+ratchet.
IIRC it's a 19mm
Main +ve connection on the starter is a 13mm nut.
I just did this the other morning in my driveway when my starter froze. (-24C)
IIRC it's a 17mm
IIRC it's a 19mm
Only liable if they were hauling ice. If it was incidental or a build up from the road, not their
issue. It's like someone wanting you to pay for their windshield froma piece of ice that fell of your ski rack.
stevenmurray
12-13-2005 04:16 AM
BreeZ
08-13-2001 05:03 AM
