B4 cabin pollen filters
While back some people were discussing cabin filters & making your own. Found a site that has 'em.<ul><li><a href="http://www.germanfilters.com/1995-audi-90-mann-cabin-pollen-filter-28-v6-late-afc-engine-p-2188.html?osCsid=50c6c5f67c571daa3d3e6b797e1ba3f3" >smell the freshness</a></li></ul>
That still requires that you have the filter housing...
i'll stick with my $.20 solution ) still works perfectly.<ul><li><a href="https://forums.audiworld.com/9080/msgs/310884.phtml">https://forums.audiworld.com/9080/msgs/310884.phtml</a</li></ul>
Yes, when I got my bracket earlier this year the dealer told me there were only 2 or 3 more left...
...in all the depots across the US. A few dealers might have them in stock, but, doubtful.
None did that I've ever seen, the bracket however is/was available...
...as are the filters.
You need to remove the "leaf guard" and install the bracket for the filter in its place. You then install the filter into the bracket.
No your car most likely does not have one. Yes you can add one (either OE or your own contraption).
Is this the bracket you are referring to?
Also how do I access?<ul><li><a href="http://filebox.vt.edu/users/mbevels/Audi/Modifications/Pollen%20Filter/DSCN0930.JPG">filter bracket</a></li></ul>
